Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
Dishwasher Should a dishwasher be flush with front of cupboard or pulled out an inch or so?
  • 706 Answers
Hello Booklice,
Normally a standard base cabinet is 24 inches deep with a 25 inch countertop ( meaning the top extends over the front of the cabinet by 1 inch) That is a typical installtion however there is no right or wrong way to set the dishwasher into cavity between two cabinets. In most installations though the front door of the dishwasher when closed is close to flush with the vertical stiles of the cabinet and does not extend beyond the overhang of the counter. The manufactures method for securing it to the surrounding cabinets will dictate the extent that it can project out. Hope that helps...
Regards
Posted on Oct 06, 2008
How do i remove the door front from my asko dishwasher?
What is a cupboard front - a panel added so it blends in?
If so, did the unit come with the panel or was it added by someone?
May 01, 2014 | Asko 24 in. D3350 Dishwasher
Hinge cord broken. Need to pull dishwasher out of cabinett
Remove front screws holding washer to cabinet. Jiggle, leveling feet may be stuck
Sep 15, 2012 | LG Dishwashers
My dishwasher was installed, then wood floors added and now the height is only 33 inches. How do I get the old one out and find a new dishwasher that is 33-33 1/4 inches tall?
Take a sawzall and cut the front legs, pull the dishwasher out until the back legs hit the new wood floor and then cut those legs from the sides. It's your old dishwasher anyway, so who cares if the legs are cut off?
Aug 13, 2011 | Dishwashers
Does the table top bush dishwasher need to be on a table top for gravity drainage or can it be in a cupboard?
no it can be in a cupboard it does have a drian pump a small one which will pump up to 3 feet from the base of the machine,cupboard installation work fine on these appliances.
Nov 01, 2010 | Dishwashers
How do I remove and replace the wooden front panel on my Electrolux ESL624 dishwasher please - had a flood in the kitchen - MDF cupboards have expanded / warped and now impede the dishwasher door from...
First I would look for very oddly placed screws. If there are none, try pulling the wood on the underside with a pair of pliers until you can tell where the tension is coming from. If it is glued on there....well you may want to use a hammer and chisel and visit www.applianceart.com for a stainless panel to replace the old one. Probably not much help but thought I would try.
Dec 29, 2009 | Electrolux 23 in. ESL624 Built-in...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher cupboard front
typically there is a metal trim around the wooden front. on the sides of the dishwasher door you will see some small screws. remove those screws and the wooden panel can be easily removed.
Feb 14, 2009 | Dishwashers
Dishlex global 300 - dish washer door won't open
I have the some problem toooo!!
I have turned it off and on from the power point and run the cycle again on "normal" and on "rinse" .
Next step will be to cut the screws with a hacksaw , remove the the dishwasher from the cupboards, remove the bottom tray and give a good clean underneath .
Feb 08, 2009 | Dishwashers
The cupboard next to dishwasher becomes full of condensation during drying cycle
Is the machine properly lined up?
Could be a small leak at the top - won't leak water, but steam can escape maybe.
Sep 03, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Miele dishwasher
we have the same dishwasher with the exact same problem. I just pulled it about one or two feet out of its little cupboard thing and the error goes away and it works again, i think that it must extend the hose and free it up a little bit.
Dec 06, 2007 | Miele 24 in. G638 Plus Free-standing...
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
133 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
