Question about Saeco Magic De Luxe Espresso Machine
Whole beans fall through the Grinder
Owing to a kitchen remodel we had our Magic Deluxe stored for 5 months. Before using it again, we cleaned everything, lubricated the parts, etc.  We even took off the Coffee Bean "hopper" and vacuumed all the old beans [or partial beans] out of there.  We didn't otherwise touch the grinder.
The machine seemed to work fine and brews without problem, but now whole beans fall through from the grinder.  I assume i must have reinstalled the "hopper" improperly.
How can we stop the whole beans from falling through?
Thanks
    Habit-Forming:
  • Saeco Expert
  • 147 Answers
You have to remove the coffee bean hopper, there are two screws on it. Below it is the grinder and there must be a rubber seal between them. Perhaps it is crooked or broken, and then the coffee beans pass and fall down.
Posted on Apr 30, 2017
3 Suggested Answers
espressodoc
  • 29 Answers
SOURCE: Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
Posted on Aug 15, 2007
mirran
  • 515 Answers
SOURCE: Water in bean dispenser/grinder
If you look at the bean hopper you will see two screw, loosen this and take off the bean hopper. Now you will see the grinder, you have to take of the adjustment on the side, that plastic on the grinder.
Now you can turn the ring anticlockwise, and take out the middle of the grinder.
Let me know if you wondering about anything
Posted on Jul 13, 2008
How to fix, "no bean light" stays on?
hi there,
have you also cleaned the output of the grinder and the doser?
You have to open it (carefully) by hand, as it is normally closed and only opens when the actuator is switched on, and clean the inside with a soft brush.
After cleaning the grinder, its outlet and the doser, the machine will have to gring at least twice ti fill-in these parts, each time saying that there are no beans. It should be OK with the 2nd our 3rd cycle of grinding.
Hope that helps,
M.
Aug 09, 2014 | Saeco Magic Deluxe Fully Automatic Coffee...
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
The beans go through the grinder very slow so the machine stops and the bean lite comes. Never does enough beans get ground to start the brewing cycle.
Hi, Your grinder is gumed up and needs to be removed and disassembled to be cleaned out. It works by timing and not coffee weight. If you dont clean it out, it will cause the grinder motor brushes to wear very quickly, and you,ll have to replace the whole grinder assembly. expensive. Use white out to mark the postion of the grinder assembly before you disassemble it. Can be a bit confussing when reassembly of the grinder, but take your time. Put it back together excactly how it was, and it'll be like new again, plus your coffee will taste heaps better. You can call me if you have problems 0401 200 901. Dazza Repairer
Oct 23, 2011 | Saeco Magic De Luxe Espresso Machine
The grinder grinds too long, then stops and then the bean refill light goes on, ---there are plenty of beans but no coffee being made. I think the grinder is not working somehow. Its a 5 year old Saeco...
The lever under the bean hopper is set to low. Push it all the way to the back.
There is a leverbehind the door in the middle top. Pull it to the minus and try again.
If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 05, 2011 | Saeco Royal Cappuccino Espresso Machine
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions.
If the grinder cleaning does not work.. You may have to have to machine serviced.
Please include the model of machine and that you would like the grinder cleaning instructions.
Email: support@cerinicoffee.com
Oct 06, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
37 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
