Question about Bose Lifestyle 38 DVD Home Entertainment System System
Audio Cable I'm having a problem with my Bose Lifestyle DVD Home Entertainment System. I believe the prongs on the audio input cord are broken and would like very much to know where I can purchase a new cord. Any ideas where I can obtain such a cord?
    Problem Solver:
  • 10 Answers
Bose auth repairer nearest to you, bose web site may sell to public (some things),it will have where repairer located.
Posted on Aug 20, 2009
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Can't get sound on tv but dvd and radio work.
Sounds like an install problem. All of your inputs (audio and video) should run through the BOSE and then only the video out needs to run to the TV. In this way the BOSE is the sound source for everything
Aug 30, 2009 | Bose Lifestyle 48 System
Bose Lifestyle 38 connection to TV doesn't work.
Is your tv hooked up to your cable box or satellite with an HDMI cable? There are several ways to input to the TV.
Aug 30, 2009 | Bose Lifestyle 38 Series IV DVD Home...
Hello, i have a vizio flat screen tv and i don't know the correct places to connect the cables of my Bose Lifestyle 48 Series IV DVD Home Entertainment System. Please help me
Does the Bose have HDMI out? Does the tv have an HDMI socket?
If it does just connect them both together. All inputs i.e. cd, ps3 dvd etc will go into the Bose.
Aug 09, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Pretty much the same problem
I have the same system. I have a Lifestyle and a Sony TV with a Samsung Blueray player. I also have an X-box 360, plus my pc with all my CDs (I-tunes) plays through my bose. Do this:
1. Use the optical cable for the blueray player to the Bose (AUX).
2. Use a digital audio cable from the cable box (either black or orange output) to the Bose CBL-SAT digital input. (it's a single audio cable)
3. For my PC, I'm using a digital cable from the pc to the Bose. I'm using the TV output because it's empty.
4. For my x-box (which I'm not too happy about) I'm using regular red-white audio cables from Bose TV input directly to the TV audio out. (You can play all of the above through this channel, but don't).
I figured the most important high quality sound should come from the blueray player and from watching regular cable tv. For picture, you should be using all HDMI connections.
Hope this helps.
MC
Jun 26, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
How do i connect a ipod to a bose lifestyle v30 system
You can connect your iPod to your Bose V30 using an ipod dock, or simply with a mini-jack (headphone jack) to RCA cable plugged into your V30's Audio-In ports.
I hope that helps.
__________________________________________
Download Bose LifeStyle V20 User Manual
Jun 07, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
BOSE LIFE STYLE SYSTEM SOUND (AUDIO) GOES QUITE FOR A SECOND
This was posted a while ago, so I'm sure it's probably been solved by now. For anyone with audio issues using this or any other Lifestyle system: If you experience audio problems (no audio, intermittent audio) from more than just 1 source (especially if it involves internal sources like DVDs or the radio) then just reset this by unplugging the power for about 30+ seconds from the bass module and the media center DC power. Check the audio input cable (multi-pin din going from the media center to the bass module) for bent pins.
If this doesn't solve the problem, you could try replacing the input cable, but those are usually pretty robust. You could call Bose at 800-367-4008 for tech support or to set up a repair if this fails.
Dec 14, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Jan 17, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Home Theater install
yes sounds about right what you are doing as long as you have 2 digital audio 'inputs' on your Bose to get the audio from the dvd player and cable box. Apart from your last part "I will then use Digital Audio from the Bose to the TV." The tv will only downrate the audio to two channel stereo, so its not worth puting audio through the tv as you only get stereo anyway, so might as well let the tvs speakers power it out themselves.
Aug 17, 2007 | Bose Lifestyle 28 System
Bose Lifestyle 38 DVD Home Entertainment System System Logo
136 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
