Question about Epson Perfection 1660 Photo Flatbed Scanner
Opening registry error
When I push the print button on the scanner and select Epson Smart panel from the pop up menu I get a message Opening registry error. This is new as the scanner worked before. What should I do?
    Problem Solver:
  • 9 Answers
A registry is a very intricate set of software instructions. A cheap registry cleaner can do more harm than good believe me, I have seen registries destroyed by cheap junk! Stay away from free registry cleaners! Try this registry scanner and please let me know if it solved your problem...
Posted on Jun 08, 2009
Brother dcp-150c unable clean 46.how can troubleshoot this problem? plz help me. thanks
To help you troubleshoot the error 'Unable clean 46', please follow the instructions given below:
- Pull out the AC plug.
- Put back the AC plug while holding down the 'Menu' button and keep holding it (15 sec).
- Now you are entering the 'MAINTENANCE' mode and 'Error 46' pops up in the display.
- Select 8 by using the arrow buttons ,push OK and select 0 and push OK.
- 00:00 00:01 OK (the display is showing this message).
- Now push the 'MONO' button 25 times until you see PURGE: xxxxx
- Select 2, push OK, select 7,push OK,select 8,push OK, select 3,push OK.
- The purge counter indicates now: purge: 00000
- Switch OFF the printer and wait for 1 minute and Switch it ON.
- Now try to print.
If issue persists, it is recommended to contact Brother Support Center for further assistance from the link given below:
http://support.brother.com/g/b/contact.aspx?c=au&lang=en&cid=2&pcatid=4
GuruAid.com
Jun 08, 2016 | Brother 32 Lc970 Bk/c/m/y Ink Cartridges...
Smart Panel keeps opening by itself
check your Startup sub-folder from Start->Programs and remove the SmartPanel link.
Feb 07, 2009 | Apple Epson Perfection 1250 Flatbed...
Everytime scanner option is selected an error message pops up
I Had the same issue, worked on it for weeks, was told it was registry issue, I reinstalled the software, said it was hardware problem....THEN I FOUND THIS AND as simple as it seems, IT WORKED.
Please follow the instructions below to help resolve this.
  1. Go to My Computer, by right-clicking the Start button. Select Explore
  2. Double-click the C: drive, then navigate to the following folders or location on the hard drive: C:\Documents and Settings\%username%\Application Data\EPSON\ESCNDV\ES00XX (where XX is any numbers or letters)
  3. Look for a BMP file or any file in this location and delete this file OR FILES THAT ARE .BMP.
  4. , can be xxxxx.BMP ( where xxxxx is the name)
Note::
  1. %username% above stands for your PC username.
  2. The Application Data folder is hidden by default, to un-hide this folder do the following in your Windows Explorer window go to the Tools pull down menu and select Folder Options
    Click on the View tab, look for Hidden files and folders.
    Select Show hidden files and folders option
    Click OK.
    you should now be able to see the Application Data folder continue in to the folder path above.
    (You may have to follow the steps again to turn off the Show hidden files and folders feature. )
  3. Removal and reinstallation of Epson SCAN does not clear out this file.
Jan 15, 2009 | Epson Stylus CX4800 All-In-One InkJet...
HP 1315xi all in one printer scanner copier config problem
Remove the HP Smartweb printing software.
1. In the Start menu select All Programs > HP Smart Web Printing > Uninstall HP Smart Web Printing.
2. Follow the onscreen prompts.
You can also open the 'Control Panel' from the 'Start menu' and open 'Add or Remove' Programs. Select 'HP Smart Web Printing' in the 'Add or Remove' Programs window, and then click 'Remove'.
If the changes you make in the Page Setup dialog of Internet Explorer are not reflected in the Page Setup dialog of the Print Clips window and vice versa ?
This is a known problem, and not unique to HP Smart Web Printing. When printing from the Internet Explorer File menu, select File > Page Setup and make your settings there. When printing from the Print Clips window, click the Page Setup button and make your settings there.
Now install the smart web printing software from the weblink provided below:
After removing the smart web printing software, please visit the weblink and download the HP Smart Web Printing 4.05 software from the webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=dj-56929-5&cc=us&lc=en&dlc=en
Just copy and paste the entire link(without spaces) in the web browser and press enter.
For more information on how to install the software visit the below weblink which leads to a webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c00793678
After performing the steps mentioned above, check the functionality.
Dec 15, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart D7460 Error Message
Oct 27, 2008 | HP Photosmart D7460 Printer
Still looking for Smart-Scan software
You can program the scan button by going to "Control Panel" and "Scanner's and Camera's.
Right Click the scanner and go to "Properties"
Select the "Events" tab
It should allow you to program your one touch button from here. I just wanna verify that you do have the CX3200 and not a Stylus Scan 2500?
Aug 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson stylus PHOTO RX425
Epson has software called "Epson smart panel" and you can select scan from the list of operations.
Turn your scanner on, (windows OS) click on "start" then click on "all programs", look for epson smart panel in programs list, click and let panel load, then select scan.
It will take some time for the scanner to warm and scan, so be patient, after it is scanned your options are to print, or save. If you save, be sure you know where its filed or "tell" it where to save, I recommend creating a new folder before in "your pictures" titled "scans" . Usually after you do this, it will save it there by default.
Dec 09, 2007 | Epson Stylus RX425 Multifunction...
Solid Red Light "Scanner Error-----See your docoumentaion and call service if necessary.
After working with Epson to unistall, re-install, and reset everything the red light still comes on. Epson, and confirmed by a repair dealer, said the light bulb on the scanner is bad. The dealer said it is cheaper to buy a new scanner. My unit still prints in b&w and color.
Nov 01, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Printer Port is used by another device
Just only check and delete error print task queue in all of printers.
Start->settings->printers and faxes.
Right click and open each printer on your machine to find which printer remain error queue and delete it.
Good luck...
sUPERTUYZ
Jun 18, 2006 | Canon CanoScan N340P Flatbed Scanner
Epson Perfection 1660 Photo Flatbed Scanner Logo
231 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
