Question about Nikon D80 Digital Camera with 18-135mm Lens
Memory card wiped clean
I purchased my D80 on 07/03/08 fitted with a 4mb memory card.I Have used the camera since then no problem.However 2 weeks ago I took some shots whilst on holiday in France I then put the camera back in my camera bag under the seat of my car.A couple of days later I took out the camera again and the letters CHR appeared in the control panel where normally the number of exposures are shown. Also when I tried to view previous photographs the words THIS CARD CAN NOT BE USED were shown.I phoned my camera shop in manchester to see if they could help they suggested I fit a new card which I have now done and the camera is working fine again.When I returned home I took my camera into my dealer who put the card into their computer and said the card had been wiped clean.I have lost around 400 images from 2 holiday destinations as a result.When the camera was placed under the seat of my car I placed a sat nav next to it which was turned on could this be the cause? my camera dealer says no but I am not so sure.If they are right then I am very worried that this problem could happen again please advise
  • stevehinch Oct 12, 2008
    Many thanks for the very swift reply to my camera problem which is now ok. I shall not hesitate to contact you again in the future should i have any problems.
    Master:
  • 479 Answers
Your camera dealer was very right.
Posted on Oct 05, 2008
  • tech gurus Oct 05, 2008
    but there are software available with the local camera repair service center where they recover the lost images with a data recovery software and you can get the lost images back as they will charge you but it will not be too heavy charge.just take your device and the same card which was wiped out.and any of the settings you must have saved by mistake that created the problem and they will also make that clear and also explain you as what to do if you face the same problem again.
    this normally happens if the card is not removed properly from the device or any rashes occur on the card the data gets wiped out.
    or also it happens if you have saved the images in the card when the battery charge is at its end.
    or.you have not saved the images properly .
Hi, i've bought a new canon camera (powershot
You probably need to move the small switch on the memory card to the open position.
Oct 28, 2013 | Canon PowerShot A810 16MP 5X Optical Zoom...
Hi i got a 32 gb sansa fuze memory card.. like 2 weeks ago. from buy.com and well today i got my sansa fuze white player. the memory card will not fit into the player. I would like to get a memory card...
From your description, you seem to have bought a regular SDHC (secure digital high-capacity) card. A Sansa Fuze can only accept micro SD or micro SDHC cards. For buying a new card, I would suggest this card from newegg.com. As for other things you mentioned: No, the card you bought is not meant for cameras only, the only reason your device uses micro SD/SDHC cards is because it is a smaller device. The 4 on your card signifies that it is class 4 which is the card's speed classification.
Jul 12, 2011 | SanDisk 1GB microSD Memory Card
I wiped all photos from card...but when I re-insert the card in camera it says memory card full
You should make it a practice to format (initialize) your card from your camera's menu each time you use it. That will wipe all data and give you a clean start. If you format your card from your camera and it still indicate a full memory card, then the card is likely bad.
Dec 20, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Camera wont stay on, new batteries and even tried wiping out the inside with a cloth and that only works for a few shots.
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 07, 2010 | Kodak EasyShare Z1275 Digital Camera
Camera will not power up. battery relativly new....was working about 2 weeks ago. Now get 1 green and 3 red blips. please help
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
I have reinstalled the software several times.
1. Get a memory card. 2. Format the new card in the camera. 3. Go into the camera menu and find an entry for "copy" or some similar topic which would allow you to copy the contents of your internal memory to your new memory card. Once the pics are on the memory card, you should be able to download them to your computer.
Dec 10, 2009 | Fuji Cameras
Camera purchased 6 weeks ago and it does not turn on now. batteries read barely into good area on battery charger. thought regular AAs would work, but they don't. HELP!!
Try new Alkyline batteries again ... (not heavy duty ones).
Make sure the batteries are inserted in the correct polarity... I'm sure it's the batteries.
Sep 08, 2009 | Kodak EasyShare C913 Digital Camera
Memory card is full but there are no pictures on my camera.
Try using the "format" option in your camera's menu. That should wipe the card clean. There's probably a file or folder that the camera can't recognize as being one it created. You might also plug the card into a card reader and open it on a computer. The format option on the computer will also wipe the card clean to start fresh in the camera.
May 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
4mb memory stick says i have no space only took 8 photos
Are you supposed to use that big Memory Stick? I think the limit is 2GB with this camera. (Sony Cybershot P200)
Jun 28, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
60 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
