Singer Down-Flo Wall Heater Series 5990 Need new off/on switch hardly used, like brand new so hate to replace the whole unit. Singer Down-Flo Wall Heater Series 5990 Model No. W-30 Catalog No. 5990 H Watts 300 Volts 240 BTU 10245 CFM 200 Control Manual
  • 236 Answers
SOURCE: Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
Posted on Jun 10, 2008
  • 124 Answers
SOURCE: Carrier Heating furnace
either the gas at the outside valve is off, or the gas valve at the furnace may be off, or the switch on top of the gas valve in the furace may be off. if they are all on, then you may not be getting a call for heat from the stat to the furnace control board. check to see if you are getting a 24 volt signal from the stat to the w terminal and common terminal on the furnace board. if you are then check to see if the voltage is arriving as 24 volts to the wires at the gas valve itself . if it is then the gas valve is possibly bad. if it is not then the board is possibly bad.look for loose or broken connections on the low voltage wiring. most unusual that the board does everything else but send power to the gas valve. you need to zero in on the valve i think and start by turning off power and that should restart the sequence of operation and you can observe it step by step . if you are not getting a call for heat then the stat may be bad be sure you are in heat , fan in auto and temp pushed up to max. if no 24 volts is sent to furnace board white and common low voltage board then stat is bad. remove it if you think its faulty and jumper the white and red wires together on the subbase. that duplicates what the stat normally does. if the furnace lights its the stat. having said that i realize the stat has to be sending a heat signal or the other stuff would'nt start. so..... back to the furnace board. check that 24 volts in from stat and 24 out to valve and that will put you on your problem item. good luck
Posted on Oct 30, 2008
  • 234 Answers
SOURCE: AC Control Transformer keeps failing.
well it has blown the fuse on the transformer, then you have coil switch bad.It could be the coil on the contath in for cooling.But can check by taking the yellow wire a loose and see if the don't blow. The red wire is one side of the transformer and the com could be any color.But look at the red wire because it is the main wire that travel the voltage throuhg the unit.
Posted on Mar 26, 2009
  • 3361 Answers
SOURCE: Need the BTU rating for an old Kenmore K948991 a/c
Your model number is not complete enough for a model check.
However, 18,000 btu in todays' units is what you need.
Posted on Mar 28, 2009
  • 1198 Answers
SOURCE: Voltage 1phase or 3 phase 240 volts BTUs M# 585epo36o75
To determine three phase, there wil be three hot wires from the breaker, which will have three wires. 240 single phase will have two hot wires, and the breaker will have two hot wires. Besides the hot wires, there will be a white wire,called common, which is used to make 110volt single phase where necessary. There should also be a green wire, which is safety ground. The BTU rating should be on the name plate. As far as I know, 2000BTU=1 ton
Posted on May 09, 2009
I have a servicecode , flo, and the temp. Will not reach the seting i have done
FLO code relates to the correct water pressure flowing through the heater tube. This is a safety procedure in adequate water flow could damage your equipment.
As this code can be one of the hardest to diagnose start by checking that all water suction & discharge slice valves are all-the-way open. If they are okay try clean or replace the filter cartridge.
If the cartridge is new or clean try temporarily run the spa with out the filter cartridge, it could possibly be preventing flow.
If the issue persists you can check that the suction fitting covers are free of debris. If the suction fittings are clear of blockages it is likely that pressure switch or flow switch (depending on your spa model) has failed.
These steps will fix a flo code the majority of the time, the pump is another potential cause but least likely.
Feb 20, 2011 | Qca Spas Majestic Series Grand Cayman Hot...
When my spa is on heat mode pump on Low Speed it will not heat up. It says FLO and flashes do I have an air lock ??? Just changed pump a month ago.
FLO is a common signal for insufficient water flow through the heater tube. Do you see the low speed pump working? If you do, then try removing your filters, if FLO goes away then replace your filters with new ones. If not, your flow switch may not be working. You could have a legitimate flow issue caused from a clog or air-lock though.
Dec 17, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
Qca Spa pumps and blower will not come on, water down to 35º f
You need to contact a hot tub technician/engineer as you clearly have issues.
'ICE' means that the water temperature is too low and therefore the pumps will be turned on to prevent freezing within the plumbing. Depending upon the spec and settings, the heater maybe disabled during 'ICE' condition.
'ECON' is Economy Mode. If you have a mode button, keep pressing it until you see 'Stan' on the display. This will put the system back into the standard mode.
'FLO' means that there's insufficient flow of water through the heater, or non at all. 1) Check the water level - top up if low. 2) Ensure that all jets are open and flow water - if they don't you may have a pump issue. 3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
'COOL' is displaying because the set temperature is much higher than the current water temperature.
As I mentioned at the start, you really should get someone to take a look at your hot tub. You may have a few issues that need resolving.
Feb 07, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Have a dayton hanging garage heater when trys to start acts like gas valve not opening heaters brand new.what should i look for
I have never seen a dayton gas heater but I will try. If this is an LP Gas
System are you using a 30lb. Cylinder, 100 lb cylinder or a whole house
Next are you sure you got the right gas unit for the right gas system?
If using LP gas did you put an external pressure regulator before the unit?
Next is the a hot surface glow coil or a spark system ignition system?
If you have to hold the controller down and press a button similar to a outdoor gas grille is it sparking?
If it is sparking,did you bleed all of the air out? This could take several
tries on a new unit. Does this have a wall mounted thermostat that
controls the heater? Finally check to make sure that the gas valve
is switched on if it has that option.
Good Luck
Jan 14, 2010 | Heating & Cooling
Will only run for about 5 min then shuts down, and will not light again. Gives a ILO and CFH on the board.
Without more info I would have to say you need to increase water flo through the heater. If you don't have enough water flo the heater will boil the water inside heater and shut down. The heater has a pressure switch that reads OK but you have by-pass valves that may be open or stuck letting too much water go by the heater. One on the pipes going in and out of the heater may have a valve bridging the two that need's to be 80-90% closed forcing water through the heater. Then there is another spring loaded disc inside the main water header that you can remove and clean or replace that does the same job only the spring controls the flow automaticly. Good luck and HAPPY NEW YEAR.
Dec 29, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
After unit shuts down sometimes the whole
you have to switch the wires from the cord that plugs into the wall. Open the furnace door, there should be a little metal box to the right or left. Open that with a screw driver. Inside there will be a white and a black wire connect to the cord that plugs into wall. Switch the white and black wires that are connected to the cord. This should fix the problem.
Oct 14, 2009 | Goodman GMS90703BXA Heater
Need belt for Everstar 5990 vacuum cleaner
I just replaced the belt on my Everstar VC-9550 and it works fine. I found it at Home Depot for $3.99. The belt is sold under Vac Belts item No. 51007 (Designed to fit Bissell Uprights, Style 7,9,10).
Apr 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Need New Microwave
Is the interior flaking the only problem with it?
It can be sanded smooth and clean and dried thoroughly, then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, if you want to replace it, I would suggest contacting Jenn-Air Customer Care here and telling them your model number.
They can probably give you the model number of a new "drop-in" replacement.
Dec 12, 2008 | Jenn-Air JMC7000 Microwave Oven
Heating & Cooling Logo
343 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
