Question about LG WM-1485FHD Front Load Washer
Door handle problem on lg wm1485fhd
it looks like the door handle on my lg wm1485fhd washing machine has somehow let the pin/spring go off it so now its not letting me to open the door. Is there a way to open the door without breaking it, and is there a way to fix the spring mechanism on the door?
thanks so much for your help
Yavuz
  • gorgeousbum Nov 02, 2008
    Hi. I got an engineer out and he showed me how to open it up - get a flat instrument/kitchen utensil - like a potato masher and slide it into the gap of the door and it should release the handle - bought a replacement on ebay (about £8) and now trying to replace the part - spring causing probs so might still need an engineer! Make sure the child lock is not on though as it will not open!! Good luck - Iona - Hubbie now done it! Yahoo now I can do my washing again - oh, almost forget make sure you ahve something on the floor below the door as the bowl falls out once you release the screws.
5 Suggested Answers
SOURCE: lg washing machine wm-1460fhd door locked wont
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Posted on Jun 16, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
MNTECH
  • 1543 Answers
SOURCE: my washing machine, which is a LG Intello Washer
That is actually a DE (drain error). Clean out the filter, located behind the access door on the bottom left side on front of the machine. If there was nothing in the filter, replace the pump motor.
Posted on Jan 31, 2011
Testimonial: "Thank You, it worked. Made the wife very happy. Thank you again."
  • 3 Answers
SOURCE: My washing machine door wont open
Sorry for VERY late solution. I have an LG front loader machine and it has just broken. While surfing the internet, I found your blog. LG front loaders have a weak door handle, that breaks after a few years of operation. All the LG models seem to be the same. Replacement door handles are relatively inexpensive and readily available.To open your STUCK door, I would use a thin butter knife....slide the butter knife between the door and the frame of the machine until you hit the metal latch. Push the latch towards the centre of the machine and open the door.In the interim until you can get it fixed, this workaround method will work, enabling you to continue washing.Hopefully LG will make future models door handles out of cast, or something stronger!
Posted on Jan 16, 2012
How can I replace door gasket?
pull back the lip and look for a wire and spring that goes around the gasket. check out repair videos on repairclinic.com or appliancepartspros.com.
Dec 16, 2015 | LG WM Washing Machines
Door handle broke
This is not an identical one but is another LG that has the same latch setup. Hope these pics help.
Mar 07, 2012 | LG WD-16115FD Front Load Washer
Not sure how the spring goes on lg 8016c washing machine door handle
http://laundry.manualsonline.com/manuals/mfg/lg/lg_washer_product_list.html Go to this sight and find your manual and the directions should be there
May 07, 2011 | Washing Machines
My washing machine, which is a LG Intello Washer WM1485FHD is display a code of OE. Could you please advise
Jan 31, 2011 | LG Washing Machines
My LG washer keeps displaying DE and makes door clicking noise and if it unlocking the door and will not start a cycle. We have bought a new door sensor, and control panel. What else can it be?
Hi dear.According to your explanation,MAIN PWB ASSEMBLY is faulty.Not the door lock or control panel.However you can try this & see if it's works.I hope that helps.Thanks. Does the spring of Latch Hook actuate?If No:Replace door assembly
Is there clicking sound once or twice when the
START/PAUSE button is pressed to start the cycle? If No:Check the DOOR SWITCH
ASSEMBLY Connector and
MAIN PWB ASSEMBLY
(Red 4 pin and white 4 pin
connector (1)).
Is DOOR SWITCH ASSEMBLY broken?If Yes:Replace the DOOR
SWITCH ASSEMBLY
Aug 21, 2010 | LG WM-2277HW Front Load Washer
Red light about door icon flashing
Sounds like a door lock problem. May just be a weak spring in the door handle which helps push the door lock pin against the contacts in the door lock switch. If you open the door and push on the pin or operate the handle the pin should return positively to its closed position, if very weak return then spring wants replacing. Take door apart to gain access to handle and spring and replace spring if broken.
Feb 14, 2010 | Washing Machines
Sometimes the door light is flashing and machine stops if i bang the door it will start again
Could be a faulty door switch or possible weak or broken spring in the door handle which activates the door pin to engange properly in the switch. Take handle off door and check spring first.
Feb 06, 2010 | Hotpoint First Edition FEW12 Front Load...
I have a hotpoint few12 washing machine and have just replaced the interlock door lock as door locked indicator kept flashing even though door was closed,sometimes happened mid cycle,and had to open...
hi
check the spring on the door handle/catch,the easiest way to check this if you close the door and it indicates that the door hasnt locked,push the inner part of the handle towards the machine,if it locks then the spring is worn.(this is more commen than the interlock).
Aug 03, 2009 | Washing Machines
How to put on new handle on indesit washing machine w133s
the spring will go so that it pushes the latch part in towards the outside edge of the door. the pin goes through the door frame, then through the spring's 'holes', through the latch, and back into the frame of the door. the spring ends should sit in a couple of grooves in the door part which may be marked/scratched by the previous one.
Feb 05, 2009 | Indesit W 123 Front Load Washer
Lg wm1280fhd Spring loaded door catch
Dee,
This one is hard because I don't have any information about your model #.  Are you sure the model # is correct??
Apr 16, 2008 | LG WD-1080FD Front Load Washer
LG WM-1485FHD Front Load Washer Logo
64 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
