Question about Nikon D50 Digital Camera with 18-55mm Lens
D50 black spot of photos
I have a black spot appearing on my photos. I can see it in play back mode as well. Suggestions?
  • Anonymous Dec 07, 2008
    I have a very similar problem. I get dark images, in the same spots in the frame (mostly), and almost always when these areas are sky or water blue. It happens on all of my lenses, so it has to be cleaning or sensor issues.
    I've had the camera for only 2 years and 2000 frames.
    Problem Solver:
  • 9 Answers
Ok, step one - find an appropriate cleaning solution - be it an air blower, like a rocket blower, a pads, alcohol and a qtip, etc. Keep in mind that it's not necessarily true more expensive means better cleaning... but I wouldn't go the dirt cheap route of alcohol and a qtip, though many claim they use it. Personally, I use a blower, but I havn't had anything more than dust thus far...
After that, prep a very clean environment, then take off your lens, and clean your mirror!!! Then when you think it's clean, try your camera again... if you still have spots, then you're going to have to clean the sensor... again, I'd use a blower, especially considering that if you ruin the sensor, you've pretty much ruined your entire camera.
If you STILL have spots, check your lens for dust, both front and back lenses. Still spots? Try another lense entirely (might be scratches). STILL on there? Then you probably have a bad sensor... see warranty information and pray :).
If any of this makes you queasy, look in your phonebook for stores that will offer repair, and try to locate the Nikon-qualified if possible.
Posted on Nov 20, 2008
My Nikon D50 in picture play back mode is giving pictures in multi colour not as pictures ?
I'm not sure what you mean by "multi-colour mode" but this page shows all of the possible playback display modes and describes them. Hopefully this helps you. I use a D7000 which is quite similar and I've never seen a multi-color mode. Nikon D50 SLR Review
Mar 23, 2014 | Nikon Cameras
Nikon D50 lcd screen goes back and forth between my image and black spots along the edge of my image. What gives?
You're seeing the blown-out highlights. Press up/down on the multiselector to select a view you like.
Mar 08, 2009 | Nikon D50 (Exclusive Package) Digital...
Taking a black and white photo.
You can't, there is no black and white mode on the D50. You will need to take color photos and convert them with photo editing tool.
Sep 11, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Yellow gym pictures
The lighting in the gym was the cause most likely. Try setting the white balance to a different mode
Feb 07, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50
Replace the button battery 1.5 voltsX2 your auto function will work properly.
Dec 29, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
D50 autofocus
Check two switchs, one on the camera body and one on the lens. Make sure they are both set to AF. At least that is how it is on my D80
Dec 08, 2007 | Nikon D50 Digital Camera
LCD Screen is Blank
twiddle the wheel at the back it fixed mine!!!
Oct 29, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Spot on photos
I have one as well. I believe it is coming from the flash. See if it only happends with the flash. If so check to see if the flash has some burn areas
Oct 26, 2007 | Nikon D50 Digital Camera
Viewfinder Blank
This suggests the mirror is stuck up in the take position. Remove the Lens and look at what is behind it In the rest mode you should see a mirror. If it is stuck up you would see the sensor window Which do you see. with the lens off - can the camera be switched on? This might just drop the mirror The mirror is surface silvered - do not touch it. If it still up then it is a repair shop/warranty replacement job.
May 07, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera with 18-55mm Lens Logo
376 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
