Fax machine isn't recognized by other fax machines
Brother mfc 7300c fax machine
I'm connected via cable on the vonage system
Posted on Oct 06, 2008
    Genius:
  • 2,120 Answers
Are you trying to send from a DSL or any other kind of digital line?
Posted on Oct 05, 2008
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
MFC 7300C
IT SOUNFDS LIKE THERE IS SOMETHING IN THE WAY OF THE PAPER PATH THAT IS CATCHINH THE CORNER OF THE PAPER, WHAT WE USUALLY DO IS TAKE A 8X10 FILE FOLDER AND MANUALY PUSH IT THRU THE PAPER PATHE TO SEE IF ANYTHING IS IN SIDE THEN REPLUG THE MACHINE AND SEE WHAT HAPPENS, GOOD LUCK BROTHER SR TECH
Nov 06, 2008 | Brother MFC 7300C InkJet Printer
Can't send a fax with Brother MFC-240C
Do you have DSL or any other kind of Digital Phone Line?
Oct 03, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Network faxing from Mac
I do not believe you can fax out through your network on this model. Please visit www.brother.com and go through the links to find your owners manual and network manual. You should find this information there.
Aug 14, 2008 | Brother MFC-8220 Fax
Scanning with the brother mfc 7300c
FIRST OF ALL YOU WILL NEED TO INSTALL THE BROTHER MFC SUITES CD THAT CAME WITH YOUR MACHINE, WHEN YOU HAVE DONE THE INSTALLATION, BRING UO THE PROGRAM PAPER PORT OF YOUR MONITOR, PUT THE COPY THAT YOU WANT SCAN ON THE FLAT BED, IN THE UPPER LEFT HAND YOU WILL SEE PHOTO OR TEXT CLICK WHICH EVER YOU ARE SCANNING, NOW CLICK SCAN ANOTHER SCREE WILL COME UP AND ASK YOU IF YOU ARE USING THE FKAT BED( THE GLASS OR THE DOCUMENT FEEDER. CLICK THAT, NEXT TELL IT AGAIN PHOTO OR TEXT OR WHAT EVER THEN CLICK SCAN, ON THE SCREEN YOU WILL SEE THE SCANNING TAKING PLACE, THEN YOU WILL SEE THE SCANNED ITEM  EITHER IN MY DOCUMENTS OR MY PICTYRES DEPENDING WHERE YOU TOLD YOUR COMPUTER TO PUT THEM HOPE THIS HELPS, GOOD LUCK BROTHER SR TECH
Nov 13, 2007 | Brother MFC 7300C InkJet Printer
Printing Problem
SOUNDS LIKE YOU ARE REFILLING YOUR OWN CART. THEY DO NOT WORK WITH BROTHER MACHINE, THE BROTHER MACGHINES ARE SET TO WORK WITH OEM PRODUCTS, CHANGE YOUR INK GOOD LUCK BROTHER TECH
Jan 24, 2007 | Brother MFC 7300C InkJet Printer
Printhead
TRUST ME , IF YOU HAVE NEVER PUT A PRINT HEAD IN YOU ARE IN DEEP S--T. MAYBE THE SERVICE CENTER OR WHO EVER SOLD THE PRINT HEAD TO YOU WILL DOWN LOAD THE INSTRUCTION SHEET. MAYBEEEEEEEEEEEEEEEEEEEEEEE THEY WILL DO IT I DO NOT KNOW AS THIS PRIORITY INFO, GOOD LUCK BROTHER SR TECH
Aug 29, 2006 | Brother MFC 7300C InkJet Printer
44 people viewed this question
jasbo
jasbo
