AMBIT Modem model
Please is AMBIT Modem model no J07M040.00 a wireless modem? Plese help me
  • ca20gh Oct 22, 2008
    Thanks, this is ca20gh.You have helped me and I can now fix up what I need
  • Stephen Medley
    Stephen Medley May 11, 2010
    The Ambit J07M040.00 is a 56K v90 dialup modem. What are you trying to do? ~Steve
I can not fine the drivers
Posted on Jun 22, 2010
  • 611 Answers
Dont remember wi fi password
More information is required...such as Make, Model, Version, etc.
Dec 25, 2013 | Ambit Lot Of 20 ubee U10c019 Wireless...
Acer travelmate 2303wlmi wifi button use to show wireless enable and disable logos when pushed now it just shows no device and launch manager is installed
Hey CONGRATULATIONS!
DAD!
"drivers obtained from acer own support site for acer travelmate 2300
then checked with a driver updater which reported that iv got the latest
drvers for my system"
Not trying to sound like Mr.Negative here but;
1) http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=761
Wireless LAN Driver/Ambit/2.10.03.2004/784.4 KB/ 12/02/2008
That the one? So am I to assume you went to your Device Manager, and in Network Adapters, you found Ambit was the wireless module, manufacturer?
No? Doesn't say?
Then remove the AC adapter (Charger), and Battery. (Laptop off, and closed, 'natch)
Turn the laptop over, bottom side up, Battery Compartment facing away from you.
Open the Memory Compartment/Wireless Modem Compartment.
(Middle panel, two Philips head screws at bottom, rectangular slotted vent at bottom/right corner. Lift the panel up on the screw side )
Remove the Ram Memory modules, ('Stick')
What is the manufacturers name on the wireless modem?
Is it Ambit?
Or is it Atheros, or Intel?
Ambit wireless modem for a Sony laptop, used for an example,
http://www.ebay.com/itm/Ambit-t62m159-00-56k-modem-for-Sony-Laptops-/220587575036?pt=US_CD_DVD_Blu_Ray_Drives&hash=item335c0b46fc
It's upside down, but see Ambit?
2) How,....did you install? I want to know the procedure you used to INSTALL. A lot of people think that just downloading a driver, is the way to go. You have to install it also.
3) Never put much stock in the entities, that claim to know if you have all of the best drivers installed.
Had one that stated I had the best driver for my ATI graphics card, installed, but was so full of it, I can't begin to start...........
4) Service Pack 3. SP/3 has caused so many problems it isn't funny.
5) Physically see if the Wireless Modem's cables are plugged to it, (Or screwed)
I would remove the cables, (Make a MARK on each cable {Wire}, and a matching mark on the modem), and clean their connectors.
I would also do the same for the terminals on the wireless modem
Use a solid pencil eraser, and use air to remove the eraser dust, afterward.
{Cables, (Wires), MUST go back to the terminals on the Wireless Modem, that they belong to }
Would appreciate your results back in a Comment.
(When you get time, of course!)
Regards,
joecoolvette
Jul 03, 2012 | Computers & Internet
I have a comcast ubee cable modem model U10C018.89. For some reason I can't get my wireless router to communicate with the modem. How can I set up my router with my modem?
Of course, the uBee modem works charmingly, no doubt about it, you can read more here http://wirelessroutersreviews.com/ubee-formerly-ambit-u10c018-docsis-2-0-cable-modem/
Nov 06, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
Need nat type 2-PS3 Cable ISP digital phone modem wireless route
you can put your ps3 in a dmz zone. if still does not work its not your router. u can keep your ps3 in dmz and get your router to open ports. u can call your router company. If still does not work its not your router more than likely. It might be your modem. i have at&t and that was my issue. i went to dmz on modem and allowed it to pass through dmz zone and ip addresses to pass through. but make sure on your comp u have spyware or something. Your ps3 can not get virus.
Sep 06, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Need driver help for ambit U98M005.05
Go to the Acer WEB site to download the drivers you need, make sure it is Windows XP or Vista version for your particular MODEL laptop.
Use this link :-
http://global.acer.com/support/download.htm
Apr 14, 2009 | Acer TravelMate 800XCi Notebook
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
