Question about Konica Minolta DiALTA CF910 Copier
What does code 0206 mean?
My copier is saying call technican for c-0206
    Problem Solver:
  • 17 Answers
C0206: Tray 3 Elevator Failure
Posted on Nov 21, 2008
Error code c-0206
Class c code. Means steering and suspension or chassis group. Abs light or stability control code. Will have to have 10 to 15000 scanner to read code. If I had access to all data for flow chart. Or call dealership to to see if it just means a level sensor or whatever simple. It will tell u what circuit of what sensor is affected. Trace wires. 95% of electrical issues are from abrasive movent or being smashed. Visible check wires
If abs sensor code, check for loose wheel bearings or hubs. Do this by jacking anfd properly supporting vehicle and push and pull on tire with alternating movements with one hand on top of tire and the other on the bottom. If any play, check if in ball joints as well. Top ball joint will show play a long time before bottom joint. Chevy independent front ball joints have special procedures to check. As u
May 15, 2014 | Konica Minolta Bizhub C550
Bizhub C-350
If your code is C 0206 it refers to a problem with the black imaging unit, if opening and shutting the door containing the toners does not cure the problem I would look at replacing the imaging unit. Hope this helps!
Jul 01, 2013 | Office Equipment & Supplies
Risograph having error code t95-056
this is a serious problem .. this means that the serial # on the boards for your machine dont match.
you can try this but it may not work. turn the machine on holding the left and right print position arrows. press the yellow clear button 1 time to bring the display to all 0000
then enter the following codes eactly as i say or you can do irreversible damage to your machine.
enter 9874 and press start. you will then see a number on the screen i usally see 51 press the yellow clear button to clear that number and bring the display to 0000 again (if yellow clear does nnot work try the orange stop button or the c button on the bottem of the keypad.) when it says 0000 again enter 1198. when the machine beeps and shows you the 1198 again turn it off by the power switch and turn it back on normally. if this does not work you will need a technican to come in and fix this problem
Jul 09, 2011 | Office Equipment & Supplies
Sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
May 24, 2010 | LG 42LD450 42 in TV
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
This is a Corona cleaning unit error. You either need to get the issue with the corona cleaning unit fixed or have a service technician turn off the automatic cleaning function. SP Mode 2 801 3 (technican will know what this code means) I can not tell you how to do this as you can total mess up the machine if the service mode is not used properly.
Turning off the cleaning will solve the error code. Technician can clean the coronas himself on service calls so automatic cleaning is not required.
Good Luck
Dec 07, 2009 | Ricoh Aficio 2015 Copier
Have a philips universal remote need to program a maxent tv
the code is 0206
Press and hold setup till light stays on
press TV button
enter 0206
press channel up
you are done
Apr 24, 2009 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
C0206 code meaning
press buttons in the exact order, utility-meter count-stop-0-0-stop-0-1. you are in service mode. now you enter counter - reset counters, or trouble and see the meaning of C 0206, if I well remember it's a corona wire problem! you can either change the wire and reset the error code or, in case that it wont work, to measure the tension at wich the corona charges!, probably the first thing will do the job!!!
Apr 11, 2008 | Minolta CF2001 Copier
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA CF910 Copier Logo
388 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
