Question about Panasonic Televison & Video
Portable DVD - LS87 Error Message H03 - Panasonic Televison & Video
    New Friend:
  • 62 Answers
Lube the slider that the laser runs on with a little grease.
Download Panasonic DVD LS87 Manual
Posted on Mar 18, 2015
SOURCE: Error H03
http://www.portable-dvd-players.org/panasonic_dvd-ls50_7_portable_dvd_player.html
Posted on Dec 21, 2007
SOURCE: error code on Panasonic LS50 portable DVD player
I also had the HO3 code...I re-alligned the laser..and now it reads the disk and shows the movie....BUT NOW I have no sound..?
I re-initialized the unit & still now sound...? IDEAS anyone..?
Posted on Jan 03, 2008
SOURCE: panasonic dvd-ls91 erro code H03
Thanks for the solution.  I moved the laser all the way to the right and that did not fix the problem so I moved the the laser all the way to the left.  Still did not fix it so I tried moving the laser back to the right with the power off and it now works.
Posted on Jun 11, 2008
SOURCE: error H03 on a portable
check out this site, it helped me with the same problem.
http://www.pechorin.com/m/2007/07/05/panasonic_dvd_ls91_error_code_H03-296059.html
Posted on Jul 27, 2008
SOURCE: portable dvd will not play
Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Posted on Sep 23, 2009
What does error H03 means af the Philips portable dvd PD9030?
Go to this link http://tech.rickumali.com/blog/2008/12/30/fixing-my-portable-dvds-h03-error
Aug 06, 2016 | Philips PD9030 9" LCD Portable DVD Player...
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
Player will not read. Error code H03 shows up on screen.
Dirty worm gear on laser (dirt or particles got caught not letting the pick up move easy go take apart but be careful many small screws and gears.
Oct 06, 2009 | Panasonic DVD-LS91 Portable DVD Player...
Panasonic DVD ls 850 H03 Code error, how to solve this problem
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Jun 02, 2008 | Panasonic DVD-LS850
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Error H03
I have had this problem for 2 years, mech.is hanging up. mine was replaced.... 3 weeks later same problem. I take out the disc and very GENTLY press one direction or the other to free it up. works great for a whole movie or several movies in a row. A small amount of electronic lube helps, just make sure you don't get it near the laser head or it will mess things up. Just clean it off real well if you get some on it.
Jan 06, 2006 | Panasonic DVD-LS55 Portable DVD Player...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
