Question about Oster 12-Bottle Wine Cellar - Black
Temp too high
My Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
  • 2 more comments
  • Luis Biaggi Oct 06, 2008
    Oster 12-Bottle cellar refuses to lower its temperature below 70º.
  • Anonymous Oct 08, 2008
    temp says 71 and will not go down
  • reevesjgbsj Nov 11, 2008
    Have had this product for about 10 months now and it worked fine until the other day and fortunately I happened to check it. It is in a location of the house not used frequently and it has a strong odor of a fried circuit card. Tried to call number in book, not available. Called number on web site, stated high volume of calls cannot take my call right now. Filled out the website information to have them contact me. Will see what happens.
  • coodle Nov 11, 2008
    mine worked fine for 9 months then suddenly won't go below 75.
  • 750 Answers
Lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Posted on Oct 08, 2008
  • Neil Golan
    Neil Golan Oct 08, 2008
    This is a defective wine cooler as so they dropped this model!
    You do not want it even if you can fix it!.
    Contact Oster and they will refund your money through the mail .
    That model is an accident waiting to happen.
    Take their refund and trash the unit!
    This just saved your house and family!!!!!!!!!!!!
    God Bless you.
    Huuum
    Please remember to leave a rating
Wont let me change temp. below 76 degrees on arcticpro
76 f is 24 celsius which is optimum temperature for comfort
Jun 05, 2016 | Arcticpro Ypc-07c Faac7 Portable Air...
My Goodman unit won't cool below 78 degrees inside during this heatwave. The thermostat says
your home may not be insulated well enough or you could have leaking duct or your system may not be charged correctly ac systems are not sized to cool below 76 degrees above 90 degrees outdoors because this will increase your utility bills during the cooler temperatures. thank your governement and all the regulations we have to follow for this. they would rather you save money than be comfortable. and we are actually in violation of state law and federal law if we install a unit that will cool below 76 degrees on 90 degree outdoor temp
Jul 02, 2012 | Goodman CKL36AR36 Air Conditioner
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
I would like to use the frig Model# FRU17B2JW for wine storage
ok im at a loss as to why you would want a refer at this temp. but i will tell you no, this unit cannot maintain that high a temp. it can be tricked into it
but that involves odd wiring and changes in the baffel; system
at the risk of a bad rating i am sorry to be the bearer of bad news
Oct 25, 2009 | Frigidaire FRU17B2JW Refrigerator
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Vinotemp 2 zone wine cooler flashes "Lo" on numeric display for lower compartment - will not hold temperature requested. Temp in upper compartment will not go below 67 even though it is set for 51. Room...
Not sure, but did you clean the filter in the back? Ours has that, and the temp starts creeping up every few weeks until I clean it. But we've never been able to get it below 58 or so, and in the last year, not below 60. I think that's just the nature of this type of cooling. Our house is also at 80. But, can keep it at 60 with the above cleaning.
Jul 22, 2009 | VinoTemp (VT60GNV) Wine Cooler
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Adjusting temp
I think your problem is a fuse in back panel has burnt out....you will need to replace it, Tthere are two fuses and one is easy to see and as usual the easy fuse is not the problem, the fuse you need to replace is probably the one in a black shrink rap on top left side of the panel. You will need to cut shrink rap off fuse and find wires. Next step cut and solder in new fuse. I belive the fuse used is a 5 amp 250v, I put in a 6 amp to repair.
Dec 28, 2008 | Oster 12-Bottle Wine Cellar - Black
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Oster 12-Bottle Wine Cellar - Black Logo
384 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
