Question about Acer Extensa 367D Notebook
Acer laptop/ Got a error when I turned it on 2day someting about it dint shut down last time.So I puncened the recommeded option. No ineternette. It also sed It had found new hardware but couldnt find river. In device manager it shoed a pronlem with a wifi adapter or something . After running the fuggin test nothing changed so I delted it. Still "web page Not found" help?
Can't logon to my acer laptop it says the following, the user profile service failed the logon user profile cannot be loaded
Shut down your computer. To do a hard shutdown hold the power button down until it turns off. You probably need it to go to last known good configuration. To to this 1. find the F8 key (keep finger on it(not pushed yet). 2. Turn Power button on and immediately start tapping F8 key. This will take you to a screen with many options; Last Known Good Configuration is one of them. It should start up. Hope this helps.
Apr 27, 2013 | Acer Computers & Internet
Hello friends plz help me while browsing net r watching movies my lap(acer extensa 4630)shut down itself.after i switched on again then it shows d msg like this [windows dint shut down successfully this is...
I can tell you that you may want to have this looked at it may be cluttered dust in the CPU cooling area of your laptop this is the indication. If not checked you will ruin your computer. When a computer gets hot it will shut down laptops are designed to prevent after a certain temperature to shut themselves off to prevent further damage. I would have this inspected right away to make sure that your not blocked up with dust bunnies............John
Apr 10, 2012 | Acer Aspire 5500 5570-2609 Laptop
While browsing net r watching movies my lap(acer extensa 4630)shut down itself
The processor has to perform large amount of work while surfing , especially while usingvideos and animationMultiple windows/tabsnumber of browserwhich in turn produces lot of heat . The heat produced is managed by the interneal heat sink and inbuilt cooling fans.But this cooling process may get affected by the blockage in air vents due to dust.So to safeguard the laptop form overheat, it automatically shuts down.
One simple try :Go to the Adobe flash properties and disable Hardware acceleration for online content. That ought to stop the system from rebooting or crashing.
Else...Its better to call a technician when it shuts down often.....
Apr 10, 2012 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
Does not want to boot up, i tried to delete partition but won't let me.
Hi, I saw ur post I have a acer 5315_2826 with not bootin im not in Expert!! U can take a chance in tryin f8 it will give u set of options try the recovery one or tha last good known location it dint work for me it might work for you or.maibe Alt+ f10 both at the same time u might hear a load beep u let buttons go I think she said it might wipe off hard drive fore people wish u luck with ur laptop:)
Aug 02, 2011 | Acer Aspire 4315 Notebook
My computer will not boot up keeps closing down
check how often it shuts down and if it shuts down when you start a particular application then start your computer and go to BIOS and leave it on there ( for example if your comp shuts down every 3 mins in normal mode then leave the comp on for 15 mins in bios to determine if it is a hardware or software issue then check in sfae mode the event log or error reporting if any hardware is causing the issue, update the drivers or try with new user or reinstall OS as last option.
Aug 10, 2010 | Acer Computers & Internet
My acer aspire 5520 keeps shutting down on boot. When i switch it on, its shows the boot screen then immediately shuts down. I had previously installed windows 7 on my second hard disk drive and the duel...
Insert your restore CD if errors are found and not fixed by the checkdisk function listed above. Turn your computer off and then back on. You'll beasked to hit any button to boot from your CD; press any key. You will then beasked if you want to install a fresh version of your OS or "Repair" acurrent copy. Choose the "Repair" option.
Dec 24, 2009 | Acer Aspire 5520-5908 Notebook
System not detecting my external hard disk
try going onto computer and see if it has removable disk right click and open or try putting usb in another port or if a disk came with it put that in .
Dec 28, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Acer Aspire 5920 will not start up either in safe mode or normal
IF YOU DON'T NEED ANYTHING ON YOUR PC YOU CAN FORMAT IT WITH YOUR WINDOWS OR RECOVERY CD
SOUNDS LIKE YOU MAY HAVE ALREADY LOST FILES
LET ME KNOW HOW THIS WORKS
Dec 27, 2008 | Acer Aspire 5920-6727 Notebook
Laptop won't shut down normally!
You should go to the BIOS and load the default settings. Also, check your device manager to check if all hardware is installed and functioning properly (no conflicts, etc).
Oct 31, 2008 | Acer Aspire 5630 Notebook
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Acer Extensa 367D Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
