Question about Motorola Mobility RAZR V3
Bluetoothspy.zip ok, I did as you said, did you get what you needed and can you help me to install it onto my phone? I do not have a cable for my phone to connect to the computer, but I will get one if you can help me.
  • 13,433 Answers
Thanks, I got it.
Looking into it now..
Posted on Oct 05, 2008
  • Ekse Oct 05, 2008
    I see that you have to extract the files from the zip archive.. you need to open the file and select extract all, extract it to your desktop for example.
    then you need to connect your phone to the computer, bluetooth or with the data cable.
    do you have bluetooth on your computer? if not you will need the data cable.
    heres the cable
    http://www.amazon.com/Motorola-Original-...
How can I unlock my phone
- Unlock all Sony Xperia 2010 Year (under test, private only)
- Unlock all Sony Xperia 2011 Year( with Test Point) (under test, private only)
- Flash All Sony Xperia/ Sony Mobile Android based mobile phones
- First in the World: Read Trim Area from Running OS via ADB( Android Debug Brigde, ADB - included)
- First in the World: Write Trim Area from Running OS via ADB (Android Debug Bridge, ADB - included)*
- Trim Area Backup Read using ADB/BootLoader(for test or Security reason)*
- Trim Area Backup Write using ADB/Bootloader**
- Single Trim Area element Read/Write*
* Not all TA elements can be written or read and not all Platforms support it.
** Not all TA elements can be written or read.
!!!Software require Internet Connection for all operations!!!
download tool
http://www.mediafire.com/download.php?7gede2no6nsccvd
Usage:
!!!IMPORTANT!!! Before any operation with any new phone - Back it UP! Later
you can restore it if somethings gone wrong.
A) To read/write Trim Area
using ADB:
1. Connect your phone to PC using USB Cable.
2. Enable USB-Debugging in Settings->Development menu
3. Install drivers
4. Go to TA work tab, click ADB in the software and press Connect.
If you need to Cancel you can click cancel to stop operation
5. Wait software to check root in your phone and try to root it.
6. If your phone is not rooted you recieve a message how to root
your phone.
7. Click Backup TA. All your TA will be backed up and saved in new
folder, same as your imei number
8. If you need to restore phone - click Write TA from Backup
9. If you need to read/write single element: enter element number in
heximal (for example 7da) and press read/write
9a. Upon write operation you will be asked to open the file to
write, so please be ready for this file to open.
using BootLoader:
1. Training: Connect phone in Flash mode (Hold the back (or the
Volume down in new 2012+ phones)) key and connect the USB cable.
2. Install drivers (x64 or x86)
3. Check if driver install ok
4. Disconnect phone
5. Go to TA Work tab and click Bootloader
6. Click Connect button. If you need to cancel you can click cancel
to stop operation
7. Connect phone in Flash mode (Hold the back (or the Volume down in
8. After successfull connect Click Backup TA (for your security)
9. If you need to restore click Write TA from Backup
10. If you need to read/write single element: enter element number
in heximal (for example 7da) and press read/write
10a. Upon write operation you will be asked to open the file to
B) To flash a S1_Boot android phone
1. Go to Flasher tab
2. Follow the procedure 1 of the read/write TA using BootLoader
(Traning)
3. Click Open firmware (acceptable formats: zipped firmware bundle,
with loader.sin inside), file format - zip or 7z (7-zip)
4. Select files to flash(eg. 1 file or All files)
5. Connect phone in Flash mode (Hold the back (or the Volume down in
6. Install Drivers (x64 or x86 - according your system OS)
7. Stand by, software detect phone and send the loader.sin from the
archive
8. Click Flash when phone is connected and software hint says "You
can press the Flash button now"
8a. Keep in mind, the system.sin takes longer at 99%, this is ok,
need wait.
C) To unlock phone
without Test Point (2010 phones only):
2. Install Drivers (x64 or x86 - according your system OS)
4. Disconnect phone
5. Enter your user id and password
6. Click unlock
8. Follow the on screen instructions (some phones require one or two
reboot).
with Test Point:
4. Disconnect phone
5. Connect the Test Point.
7. Keep the Test Point connected
8. Click Unlock
9. Stand by.
9a. Longer in description faster in process about 20 seconds.
Apr 19, 2016 | Sony Ericsson XPERIA X10 Cell Phone
Nokia N70 games intall
Just copy the jar file to you phone via bluetooth or cable. Then open it and it wil install. Zip files are not installation files. you must unzip this file on ur pc first, then copy the file in the zip archive to ur fone. It may be a jar or sis. jad will not work on the n70.
Hope this helps.
Apr 03, 2009 | Nokia N70 Cellular Phone
Uploading pictures onto my PC
It took me a while:
go to Tools (bottom centre)
scroll to #8 -- USB Mass memory device
Plug in the "official" cable
Ignore the computer's complaint that it can't find the software
Press OK on the #8 "connect" option
Your phone screen will go blank shortly
Give the computer a moment and it will tell you it's found a new memory device and will show you the contacts. You can copy to and from the memory card -- pictures will be in my_pictures, etc.
When you're finished, press OK to disconnect the phone -- then unplug the cable.
Enjoy!!
Cheers, Dallas
Feb 25, 2009 | LG VX-8700 Cellular Phone
Can't connect my motorola L6 to pc..
What you need to do, is to use Motorola Phone Tools (MPT) to get the phone connected Via bluetooth or the data cable and this will install all the drivers for your phone.
Here is a link to download the MPT free....
There are two ways of doing this. The first is using Bluetooth, which is a wireless connection and the second is using the data cable and Motorola Phone Tools (MPT). I would recommend that you use the data cable because it is very thorough and it has a simple user interface.
The data cable you can purchase at any phone store or even on Ebay. As for the software MPT, here is a link that you can use to download it.
The link is:
http://rapidshare.de/files/34829443/MPTools_4.04b_Full_by_soft-best.net.zip
If they ask for a password to open the file after you have downloaded it then you can try this:
Password: Freshwap.com
When you copy and paste the link, you will be directed to rapid share. Then you scroll down the page to the button “free” located at the bottom of the second column. Click on the free button and then you will go onto another page. This page should have a timer counting down. This is how long you have to wait before you can download the file. When the timer expires, then you can enter the 3 character confirmation code that they give you, and then hit download and that’s it.
You will also need WINZIP, that is the software they use to zip the files. This you can get anywhere on the net but you can check: www.downloads.com if you don’t already have it.
Hope this helps
Chris (ziraffa)
Jan 15, 2009 | Motorola Mobility L6 Cellular Phone
Cant upload music onto my new samasung m540
its very simple download samsung pc studio 3 and update the driver from the app you just install
Dec 21, 2008 | Lands Phones
Bluetooth spyware
would you be willing to email me the file / software? I will email you back with instructions ones I have figured it out myself.
other option would be to use remote support so I could see your computer screen.
which do you prefer?
Oct 05, 2008 | Motorola Mobility RAZR V3
Eurovox maxv code
i am looking new codes for eurovox max v 2008 cable box
Jun 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
Motorola RAZR v3i THEME installation.
First unzip the zip file. If you need unzipping software, use www.7-zip.org. Extract all the files inside to your Desktop for easy locating. Be careful of unzipping a zip file. If you do not totally trust the source, zip files can have nasty viruses and malware on them. People sometimes load these onto P2P file sharing networks - maybe to discourage people from sharing. People do it anyway, just know the risks.
For the next steps, I need to know whether you are using a SD card or a USB cable to get the data into your phone.
Assuming it is an SD card, you need to have a SD card reader for your computer to transfer the files into it.
If it is a USB cable connection, you need a media managing software such as Motorola Phone Tools to do the transfer.
You could also do it with a mobile web service, if you have that service from your carrier. You'd need to upload the unzipped file(s) to a wap server, but there are many that are free.
Jun 11, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Need help on music?
the data cables only come with software to install the phones driver onto your computer you need Motorola mobile phone tools in order to transfer things to your phone. You do need to pay for this program as well but it does have free trial software 2 other amazing programs are Mobiledit and Mobile Master. I'm sure there is some free software somewhere but I doubt they work very well. IN FACT, the whole process is really quite complicated and I will try my best to write a full guide on how to do it.
Mar 08, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
