Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
Temperature Setting Dial in Fridge
G'day I recently got an old Kelvinator Cyclic Defrost 340 fridge/freezer from a friend of mine however he has not used it in quite some time, i just need to know on the fridge cooling dial which is the colder setting 1 or 9? also how long should a fridge like this take to cool properly cheers
  • Louise Holly Dec 23, 2008
    I have a Kelvinator fridge freezer (KHBF336HWG). The temp setting ranges from 1-6. Please can you clarify whether 1 is the coldest setting or 6! I have a fridge full of Christmas food can you suggest which number setting would be best.
    Many thanks
  • 943 Answers
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Posted on Oct 06, 2008
Does this mean that #9 is the highest temperature, or the highest power (ie. coldest?)?
Posted on Oct 07, 2008
  • david hines
    david hines Jan 06, 2014
    Exactly. In a thermostat, a higher number produces a higher temperature. In a volume control, a higher number produces a higher ammount of power. The old Kelvinators did not indicate if a higher number produces a higher temperature or a higher amount of cooling power. Which is it, please?
What is the correct setting for a kelvinator fridge freezer
mine has 5 setting, i dont know what model you have but i set mine on 3 and it keeps everything frozen, you may have to experiment as to what setting you like to have it
Nov 24, 2013 | Kelvinator Freezers
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
How do you defrost the kelvinator cyclic 300 fridge?
hi,
a manual defrost? unplug and get a 9by11 cake pan and a bunch of towels and a hairdryer. put the hairdryer on LOW only and get it positioned in the freezer (door) compartment so its pointing towards the back. cake pan in the bottom towels below. and on the floor. leave the door open about 3 or 4 inches but NOT shut so you have some air circulation. and check it frequently. make sure the hair dryer isnt pointed at the plastics at all. takes a day. pull it from the wall, remove the rear access cover behind the fridge and blow it out with a vac or air compressor too. theres an access panel inside the freezer and if your handy, your ice blockage causing that problem lives behind there in the freezer. use caution if your going to attempt taking that plate off inside. use nothing sharp.
jm
Dec 08, 2010 | Kelvinator Freezers
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
2,690 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
