Question about Canon PIXMA MP600 all-In-One InkJet Printer
Pixma ip1600 printer is not feeding paper properly. the paper is going in at a angle
    Scholar:
  • 116 Answers
The gears in the paper feeder tray are getting blocked somewhere or are worn out please try to clean the gears.they are exactly below the feeder.white in colour.and r not very small you can easily locate they r on the right side with printers front facing towards you.please check the gears and make it clear.
Posted on Oct 05, 2008
Hello! I have canon ip1600 pixma printer. The paper in the printer does not feed properly. It twists to the right. Please suggest what to do.
Hi! You might have a broken paper feeder. It's a rubber coated hard plastic that rolls. I suggest you bring your unit to the canon service center.
Jan 17, 2011 | Office Equipment & Supplies
Hi! I have canon ip1600 pixma printer. The paper in the printer does not feed properly. It twists to the right. Please suggest what to do.
there is something in the paper path, in an area you cannot see. Look carefully, from the front and back. Often the unit will need to be dismantled.
Oct 18, 2010 | Canon PIXMA iP1600 Printer
How do you fix a paper feed problem in a Cannon iP1600
  1. Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
  2. Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
  3. Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
  4. Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
  5. Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
Good Luck!
Aug 23, 2010 | Canon PIXMA iP1600 Printer
Canon ip1600 jams paper when operated.why?.
You got a small shred of paper stuck in the paper track somewhere.
You could try feeding a sheet of light card or heavy gauge paper through which may clear it for you if that doesn't work you're going to have to get into it a check out all the rollers, right up to the edges, of the paper track. Don't forget to disconnect from the power source before you take any covers off.
Apr 22, 2010 | Canon PIXMA iP1600 Printer
Canon ip3300 paper feed not working properly
There is a small switch on the bottom left on the front of the printer that was selecting envelope feed instead of paper feed. Changing this fixed the problem.
Jan 14, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Paper won't feed
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper; they just contiue to roll. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). After blowing, if you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Dec 08, 2009 | Canon PIXMA iP1600 Printer
Paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper.
"paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper."
I am having the same trouble, what was the solution?
Oct 15, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Cannon printer feed paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Canon PIXMA iP1600 Printer
My cannon pixma ip1600 has a paper feeding problem. It can't feed the paper to print. help please.
Canon PIXMA MP600 all-In-One InkJet Printer Logo
85 people viewed this question
old marine
old marine
