Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore model 98702
On the stacked washer/dryer Kenmore model 98702, can just the washer be replaced?
  • 15,935 Answers
No - it is one body. it cannot be replaced - only repaired.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Are the Kenmore stacked washer/dryer run on 120 or 220?
Models will be manufactured for each. Check the plates on the back; I'm sure it will be marked there, or in your booklet (?).
Cheers,
John C
Mar 03, 2011 | Kenmore 98702 Stacked Washer/Dryer
The water does not shut off when filling the washer tub in my Kenmore stacked washer/dryer, Model No. 417.93872200. The water keeps rising and overtops the washer tub. What part(s) do I need to replace?
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Oct 13, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer / Dryer WON'T DRAIN
Did the unit ever drain? If it did, has anything changed?
Make sure the drain hose in back has not pinched (unit slid backward against the wall, pinching the hose.).
Motor is two speed, and if it's not kicking to the high speed, then there may be a timer problem.
Jan 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Combo Model 417.98702890
There is an EXTERNAL fuse on the back of the unit.
Service manual is inside the machine's shell in plastic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
HOW DO YOU TAKE THE DRYER OFF?
If it is stack from the factory (ie..came as one peice) you cant
Jul 24, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Jun 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
128 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
