Question about Magic Chef CMV1000B Microwave Oven
MCO153UBF microwave-range hood - broken door handle
I have a MCO153UBF microwave-range hood, and the door handle has broken. I've been able to find a replacement handle on-line - the configuraton appears to be straightforward - a post at the top and bottom of the handle with an accompanying clip (also top and bottom) to hold everything in place. The posts appears to just slide in (until the clips engage) but for some reason my exploratory attempts to pull the broken piece of post out have failed. I can get a pretty good grip with a pair of side cutters but it won't budge. Any ideas?
3 Suggested Answers
  • 37 Answers
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Posted on Aug 03, 2007
MicrowaveSvc
  • 8871 Answers
SOURCE: My magic chef over the
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 02, 2008
MicrowaveSvc
  • 8871 Answers
SOURCE: replace door handle on mco153uq
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can order parts here.
Posted on Aug 30, 2009
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
How do you take the door off? I too have a broken handle and door...
If only the door handle is broken, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle on this model has two parts (items 3 and 8). Depending on what is broken, you may only need to order one or the other. Both parts, combined, is still only about $20. The part numbers are WB15X10119 and WB15X10120, respectively.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE Profile spacemaker 2.0 handle is broken. How can I change it?
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you
May 31, 2010 | GE Profile Spacemaker Over-the-Range...
How do i replace a broken over the range micro wave door handle
The door handle is a simple repair that can be done with the door in place, or removed. And, you do not have to uninstall the oven if this is an over the range model.
It would help, however, to know what brand and model microwave oven you are referring to. All ovens are not designed the same and are assembled in different ways. What I have provided you with is the basic information that applies to most microwave ovens. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you
Apr 24, 2010 | Microwave Ovens
Broken handle on over the range microwave
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 5304440323.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Apr 12, 2010 | Frigidaire FMV156DC Microwave Oven
Kenmore mirowave # 72162643200 handle is broken
I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
As for the door... I very CAREFULLY used super glue/ gel and it did the job!
Mar 27, 2009 | Kenmore 62643 Microwave Oven
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Microwave Ovens
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
Magic Chef CMV1000B Microwave Oven Logo
98 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
