Question about Philips Magnavox Learning Universal Remote
Deactivating tv remote control codes
How do I reverse a code that your not sure what was put into the tv and bring it back to the default?
    Problem Solver:
  • 7 Answers
I am not certain these are the instructions for your specific remote. If you are brave, give this a try.
To Clear all Learned Commands under a mode
Clearing learned commands is helpful if, for example, you
replace your CD player with another brand or model. If
you had learned a feature from your old CD player’s
original remote on to this remote (such as RANDOM
PLAY), that feature would no longer work for your new
CD player. Should you wish to remove or clear one or
more “learned” commands, follow the steps below:
1. Press and hold the SETUP button until the red
indicator turns on. Release the SETUP button.
2. Press and release the button for the mode you want
to clear (TV, VCR, etc.). The red indicator blinks off.
3. Press and release the LEARN button TWICE. The
4. Press and release the SETUP button. The red
indicator turns off. All learned Commands under that
mode are now cleared.
Master Clear - To Clear all Learned
Commands under all modes
2. Press and release the LEARN button TWICE. The
3. Press and release the SETUP button. The red
indicator turns off. All Learned commands in the
remote are now cleared.
If you would rather error on the side of caution, here is the link to Philips Customer Assistance. It will help you locate the correct model number and the appropriate User Manual.
http://www.support.philips.com/support/html/index_us_en.html
I hope this helps, good luck!
Kym McC
Posted on Oct 11, 2008
How to program for panasonic tv?
from http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR350
Code 1003 for Panasonic TV
Code 1054 for Panasonic TV
Code 1062 for Panasonic TV
Code 1109 for Panasonic TV
Code 1170 for Panasonic TV
Code 1248 for Panasonic TV
SEE ALSO
RCA Universal Remote Control Programming Codes
http://www.thompsontv.com/rcarc.html
Good Luck!
Apr 13, 2010 | RCA RCR350 Remote Control
Tip
RCA Universal Remote Code Search Models RCR312W - RCR311BN - RCR311BIN RCR311SN...
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
TV 2 remote, have to use the TV remote instead of Dish remote for the volume control
You will need to program your dish remote to your tv, find the 3 digit code for your tv and on your dish remote press the TV button till all lights light up at the top of the rem, then enter the 3 digit tv code and then press pound. this will now programm that rem to your tv. be sure to press the SAT button to put back into SAT mode to operate your Dish programming.
Nov 01, 2009 | DISH Network IR Remote Control
RCA universal remote
Try it without a code. Turn your tv off. Press tv then press the on.off button and tv button at the same time. When it lights up, press play every five seconds until the tv powers off. Next press the reverse button every few seconds (sometimes takes a while), until it powers back on. When it powers back on hit the stop button to save the code.
Sep 08, 2008 | RCA Universal Remote Control
Tip
I hope that helps.
on Apr 06, 2010 | RCA RCR311B Remote Control
Emerson remote control
It sounds like you loaded a wrong code to the TV. Though I don't know how. You should have been loading the TV's code to the remote. but if nether remote will work then something got loaded to the TV. check your TV's owners manual. There should be a way to bring everything back to default. Usually by pressing a series of buttons on the menu and turning on the tv. I wouldn't know the set of buttons as every tv is different. But it should be in the owners manual or on the web site. Reseting the tv to default should cure the issue. Sony will help you but they will charge you for the call. If you cannot find the information in the owners manual go to sony's web site and check the FAQ section to see if someone else has had this problem. Sony is usually fairly good with information on the web. You should be able to find what you need to do to take the TV back to default. BEWARE THOUGH! any information you programmed to the tv will be lost when you do this. You will have to reprogram it. (TV channels etc...)
Jan 24, 2008 | Dryers
VChip password forgoten
http://www.youtube.com/watch?v=0Zc8Jbq3qE4
Here's your  answer - Hold the down volume control on the TV. Then press the remote # 0. This will bring up the reset password menu. Then reset the password. We need a kid to solve are problems. FWL
Oct 19, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Jul 01, 2007 | RCA RCR450 Remote Control
Philips Magnavox Learning Universal Remote Logo
261 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
