Question about Nikon Cameras
When you push the buttom to take picture there is delay. How can I stop this from happening?
  • Anonymous Dec 11, 2008
    My wife has the same problem with her Nikon CoolPix L3. There is a 1-2 second delay.
  • lynntelk Dec 11, 2008
    My wife has the same problem with her CoolPix L3.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Before the peak of action press the button halfway to focus and meter. When the action peaks, press the button the rest of the way.
That will get rid of much of the delay. A higher-end camera (like a DSLR) will have even less delay, but will cost more money.
Posted on Dec 30, 2009
Will not turn on.battery tested and was fine.
Bad push buttom, or something inside the buttom, like any cola or kool aid between the push buttom.
Try to check if the push power buttom it´s working.
Dec 07, 2015 | Cameras
How do I set the camera so I don't have a delay, I try to take a picture and there seems to be a delay and I miss the shot.
This is a common situation with almost all point-and-shoot cameras. The delay is because the camera has to do so much when you push the button. Bulkier and more expensive SLRs eliminate the delay by having more hardware to handle the various tasks.
You can reduce the delay by anticipating the action. If you know where the action is going to happen (a child blowing out the candles on a cake, or right in front of a soccer goal, for example) aim the camera there and press the shutter button halfway and hold it there. This meters the exposure and focuses the lens. Then when the action finally happens, press the shutter button the rest of the way. With the camera having done most of the work when you pressed the button halfway, there will be much less delay.
Again, the delay is a basic "feature" of the camera design. It can't be completely eliminated, but by pressing the shutter release halfway it can be reduced.
Jan 30, 2013 | Kodak EasyShare Z1015 IS Digital Camera
Setting timer on window unit to turn on and off
Hi Jessica Yacopino - Generally speaking, Frigidaire air conditioners timer option typically have the same procedure. The unit must be in the ON position for the timer delay stop option. For delay start, the unit must be in the OFF position. First, press time button. Then to adjust timer setting, tap or hold the UP arrow or the DOWN arrow to change delay timer at .5 hour increments, up to 10 hours, then by 1 hour increments up to 24 hours. The control will count down the time remaining until start (8, 7.5, 7, etc.). The Delay Start mode automatically selects cooling with maximum Fan Speed. The temperature maintained will be the same as previously set. To change the set temperature, press "COOL" then Up or Down arrows until the desired temperature is indicated on the display. After 5 seconds, the control will automatically change the display back to the hours remaining until the unit will start/stop. PRESSING the unit On/Off button at any time will cancel the Delay Start/Stop function. The Delay Start/Stop Feature will work until the unit either starts or stops. Once that happens the above steps have to be repeated again.
Oct 03, 2012 | Frigidaire FAS257S2A WallWindow Air...
How do i take a time delay pic with my canona550 camera
I don't have your exact same camera but on mine you push the menu button, go to tolls and you'll see settings like +1 , +5 +10 these are the delay times once you select one you push the shutter and mine beeps and then beeps faster as it gets closer to the time out and then it takes the picture ( this is handy for taking pictures of yours elf and mine has a little light on the front that flases as it counts down and it stops after to takes the picture.
Apr 03, 2011 | Canon Cameras
I'm driving from work and all gauges fail, checked fuses, gigled key in ignition, nothing. help
This has happened to me before also. After some research, I found that this is a common problem with this model. When the gauges stop working, push your odometer reset buttom. May take a few times but oddly enough it works great.
Jun 29, 2010 | 1998 Jeep Cherokee
Buttoms on Gaggia Titanium not working
Hold down the descale button for 5 seconds its the double ellipse, that should put it in a clean cycle. It is possible that it needs cleaning and it locked up because it was not getting cleaned.
Sep 10, 2009 | Gaggia Titanium Espresso Machine
My girlfriend took the batteries out of the Phillips universal remote. When she replaced them with new ones, the remote would not respond to the Toshiba TheaterView big screen television it was programmed...
first push code buttom then press tv then start pushing power buttom until tv go off (do not push power again after tv go off if this happen need to do everything again)then press enter and try again
Jul 27, 2008 | Televison & Video
There is a long delay taking pictures
Check to see if the self-timer is on. You can set the timer to 0, 2, or 10 sec. A 2 sec. delay will help to prevent blurry pictures. But setting the self-timer to 0 will take the picture as soon as you push the button.
May 26, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
37 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
