Question about Acer Aspire 3680 Laptop
Cannot find my E: Drive CD/DVD Player, just disappeared. HELP
I did a vista update after months of not updating and everything seemed ok, then I realized I lost my e: drive taking away my ability to down load music or dvd's. How can I relocate it. I tried recovery but no help,. I went to auto play updates and made sure they were on the correct settings. someone out there help me locate and fix this problem.
thanks
chris
    Scholar:
  • 43 Answers
This e:/ drive ur talking abt,is it ur cd/dvd drive? if it has disappered then u can try these steps. following them would clear the upper and lower filters from the windows registry which might not have updated it self with the vista updates so i really am sure that this would solve ur issue.
Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Step 4: Restart the computer loadTOCNode(3, 'resolution'); If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program. or u can try to burn the disc using the inbuilt burner program that cam in ur laptop
Posted on Oct 06, 2008
Presario F700 Cant Burn/Write
try reinstall it with old driver, first uninstall the updated driver, then install it again with old driver.
When it's OK, don't update the driver.
Dec 08, 2009 | Compaq Presario 700 Series DVD-Rom Drive...
I have an intermittent disappearing Pioneer DVR-K17B drive
I took my laptop to a friend who pointed out that Microsoft's online FixIt feature only has "single fix" capability. The error is most likely caused by conflicts in the registry between different applications which use the optical drive, like HP QuickPlay, Nero, iTunes etc. He said what I needed was an "Expert" FixIt tool which would be able to fix multiple conflicts at the same time (only available offline to Microsoft Certified "Expert" Tech people) - hope that helps point you in the right direction, SMK.
Oct 14, 2009 | HP Pavilion dv9000z Notebook
HP Printer Continually Drops Off Vista OS
Click on Start -> All Programs -> HP -> HP Update and run this utility. Last month, HP released an update that directly addresses this issue with the PhotoSmart series printers and computers using Vista. You should install any updates listed here, including the connectivity update.
Jul 26, 2009 | HP Photosmart C3180 All-In-One InkJet...
Dell Laptop inspiron B130 Cd/DVD player will not work
DVD43 is freeware and does not get updated very often. Although, there has been at least one update recently according to the threads I could find. I would try updating to the most current driver for DVD43 and see if that fixes the problem. If not try to remove the program again once the drivers have been updated. Some times a program will not remove through regular means when something in the program is corrupt. Hope this helps...
Jun 02, 2009 | Dell Inspiron B130 Notebook
Vista lost DVD/CD Drive But fine with XP
From your description, it is look like registry issue.
MS has solution to fix that problem by editing registry.
just follow the step from microsoft website in order to update registry:
http://support.microsoft.com/kb/314060
Jan 05, 2009 | Acer Aspire 5050-3242 Notebook
Dvd player
try updating the driver for your player that supports windows vista. if the player is not detected in your vista but detected in your bios try updating your bios as well. or you can try to do a system restore by going to start all programs accessories system restore. choose a date which you believe your player to work fine.
Sep 26, 2008 | Samsung SN-S082D DVD RW Dual Layer Burner
Dvd cd rom drive disappears
Please access the link given below. This link talks about a problem in the operating system.
http://support.microsoft.com/kb/q270008/
Let me know if your problem does not get resolved with this.
Thanks
Aug 21, 2008 | Microsoft Windows Vista Home Premium with...
HP Pavillion not reading audio CD
It is possible that this is a drive issue, I've seen drives that one of the optical reader device has gone out, but generally it'e the DVD reader and will only read CD's. It's very rare that the CD reader goes and the DVD reader works. Before you replace drive, if it's only music CD's (you didn't mention program CD's), then update your media player. If it still won't play, then unistall the media player and completely reload it. At this point you can replacse the drive.
Jun 28, 2008 | Computers & Internet
CD driver disappear after running Windows update
hi there
first read the updates that windows downloads before installing it to your computer. do a custom install. there might be an issue with one of the windows update with your dvd. its a good thing that you have system restore.
fixya!
Jan 31, 2008 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Mi dvd-burner doesnt recognize blank DVDs and doesnt burn them
try downloading www.slysoft.com thier Dvd player play and burns everything and you can do a trail run for 20 days or so lala linda
Oct 03, 2007 | NEC ND-3540A DVD RW Dual Layer Burner
Acer Aspire 3680 Laptop Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
