Question about Moultrie MFH-DGS-200 Digital Camera
Moultrie I450 Game Spy
When I setup/configure my game camera it will take pictures and store them to internal memory, but when I insert an SD card it never stores them to the card. I have tried different cards, different batteries. Also when I do a diagnostics test I get an error code = 000400. Any help would be greatly appreciated!!!
THANKS IN ADVANCE!!
  • Moultrie Expert
  • 296 Answers
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Posted on Mar 06, 2010
  • Ronald Lockhart Jan 03, 2012
    that error code 000400 means camera not communicating with memory card.
There is no button on front to release battery compartment
No, it is on the bottom
Page 3
Slide the UNLOCK switch on the bottom of Camera and use the knob to pull the slide-out
Battery Tray. Install eight (8) AA size alkaline or lithium batteries with polarities as
indicated in the Battery Tray. Re-install the Battery Tray and insert your SD card.
We recommend that you format the SD card inside the camera before taking pictures
http://images.ebsco.com/pob/moultrie/catalog/m-990i_manual-english_web.pdf http://images.ebsco.com/pob/moultrie/catalog/m-990i_manual-english_web.pdf
May 08, 2016 | Moultrie Game Spy M-990i
SD error show on the screen
SD card it the memory card you should insert. Fine a not to expensive on on the net, and order one.
Sep 02, 2014 | Moultrie Game Spy M-100 Mini 6.0 Megapixel...
My moultrie trail game camera d-40 will not store pictures on memory card. I have tried multiple memory cards. The card I have been using is not very old and has worked fine until now. Camera is showing...
Is the small switch on the side of the SD card pushed up toward contacts? Has the card been formatted by a PC(A NO-NO)?
Remove card;turn camera on..go to setup; press up arrow once to get "DELETE ALL IMAGES NO?";press select button to get flashing "NO"; press up or down button once to change flashing NO to flashing YES; press select once...should get "DONE";press select until back in "SETUP...Turn camera off insert SD card and try again...may need new SD card.
Oct 24, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My camera flashes "note: if sd card is
After Note: , it should say internal memory must be erased in order to use the SD card. Yourn LCD is probably about to puke so you don\'t see the second line.
Have fun with the junk LCD replacement parts.
Sep 17, 2011 | Moultrie 6.0 Game Spy Infrared Camera...
My camera MFH-I-40 is giving me a message that says, "internal memory full. Memory needs to be erased". I do not have my manual. How do I erase the internal memory?
Solution 1
Go to options and look for format.
Solution 2
Move all your pictures to a memory card and free all your internal memory space.
Jun 09, 2011 | Moultrie Game Spy M45 Digital Trail Camera
How much internal memory does the MFH-I-40 have?
Your Moultrie MFHDGSD50 Game Spy Camera has 16 MB internal memory and has an SD Memory Card Slot which is expandable up to 16 GB.Please leave me a reply if you need further assistance.Please don't forget to rate me if satisfied.Thank you.
Jun 08, 2011 | Moultrie MFHDGSD50 Game Spy Camera D50
Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Oct 20, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie MFH-DGS-200 Digital Camera Logo
841 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Steve
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
