Question about Mitsubishi WS-55807 TV
GHOST/MULTIPLE IMAGES AND COLORS ON MITSUBISHI WS55807 PROJECTION TV
Recently we have multiple images and distorted colors.
How to fix
  • 4 more comments
  • ddsam Oct 05, 2008
    I did that. Went back to the factory setting, did not work.
    Any other suggestions?
  • mnjojo Oct 13, 2008
    We have the same problem. The picture starts out OK and then after about 20 min, it gets distorted. At first resetting defaults worked, but now it doesn't. Sometimes it corrects itself, sometimes not.
  • Anonymous Oct 15, 2008
    distorted picture on the left side of screen
  • citizens15 Oct 16, 2008
    seems like the red bulb won't focus even when i try manualy
  • Anonymous Oct 26, 2008
    rouding in start up
  • davinz Nov 23, 2008
    I have the same problem. The red won't move over to the right far enough to re-align with the blue and green.
    Genius:
  • 1,148 Answers
In the menu ,,under settings usally ther a convergenge option,,what it does is realine the colors,, that should do the trick,,if your tv has that ,,good luck
Posted on Oct 05, 2008
65" rear pro. Convergence IC Repair
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Ghosting of the image
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Distorted image and color separation and overlap
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Blue arc extends acoss width of mitsubishi ws65869
The WS65869 is a CRT based projector, no bulb. It sounds like you have a convergence failure. The convergence output ic's will need replacing.
Jan 02, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
Mitsubishi rear projection 50 inch tv picture is distorted and has ghost images
1. Pull the Video and Audio cables; then (if you are to obtain a small steel brush) very gently polish both ends of the cables.
2. Replace your current Video cable.
3. Verify Frequency setting on the TV.
Sep 23, 2008 | Televison & Video
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Color problem with DLP TV
If pic. is distorted when warm :. Suspect the FMT PCB part # 930B924002
Sep 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55807 TV Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
