Kenmore 90 series
SOURCE: Kenmore 80's series dryer
HI thanks for the question. you said it took 3 or 4 hrs to dry a load. check the venting its cheap . clean all venting. thanks the appliance doc. please rate my answer. thanks.
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
SOURCE: sears kenmore dryer 70 series will not dry clothes, unit does not
faulty heater element try replacing it at rear panel bottom left panel behind drum at rear cheap to mend yaself
