Please help me
I've instaled a usb speakers to a Dell pc and appears an error that says no software available for this device and i just got this speakers yesterday their brand new. And when i go to volume control it doesn't apear any audio device
    Genius:
  • 1,124 Answers
If after connect your usb speaker cable the system it is asking for software (drivers) you have to install them to get your audio working properly. Check it out the box of your new speakers for a installation CD.
You can also verify:
Check if your audio es working properly (start >> control panel >> sound and audio devices)
Check if your sound card is properly installed (My pc >> Properties >> Hardware >> Device Manager >> Audio)
Posted on Oct 05, 2008
Only one of my two headphone jacks plays sound
you can use a usb sound device its very cheap 2 $ in value
Feb 02, 2013 | Dell Studio 1737 Laptop
DELL DIMENSION DVD ROM CODE 10
please install dvd driver cd and software
May 07, 2012 | Dell Computers & Internet
I can't get my usb devices to work on my dell 4600 series pc. It won't reconise anything I try to plug in to the usb ports.
Try deleting your usb drivers.
Right-click My Computer
Manage
Device Manager
USB Controllers
Delete (Generic USB Hub)
Restart computer
(Windows will auto-install the drivers, on reboot)
Plug your device back in, and see i've it works.
ALSO PLEASE RATE MY SOLUTION
Jun 21, 2011 | Dell Dimension 4600 PC Desktop
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
I have dell Inspiron 1420, i reformatted my system using windows vista home edition but after proper installing all software my internal speaker doesn't work please advise;
It must be a Volume device drive problem,please try to update your volume device drive software,find your original dell Inspiron 1420 volume device driver software or download it from www.dell.com
Oct 05, 2010 | Dell Inspiron 1420 Notebook
USB ports do not work. No sound from Speakers
Hi I am Vortash ... .. if you have your audio drivers re-install them after you Check the sound settings in advanced and make sure the speakers are not disabled .. As for the usb ports check in device manager that the usb is installed and enabled and that your drivers are working if not update if it asks search web say yes if your on the web where you are and get the latest ones ... hope this helps Vortash
May 02, 2009 | Dell Inspiron 1100 Notebook
I cannot find a driver for my Toshiba mass storage device.
Go to BIOS and change the USB setting to full speed and save it and continue. I am sure it will work after that....sodeep
Mar 24, 2009 | Computers & Internet
WIRELESS CARD FOR LAPTOP
Hi
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
May 07, 2008 | Dell Latitude D600 Notebook
Power surge to usb port when installing cd
Delete all the USB ports in the device manager
Restart the computer to let XP install all the USB ports again.
Go to the first USB port and right click on it and go to properties. Then on the advance tab click on do not show warnings.
This should resolve the issue.
Is your PC a Dell by any chance?
If so there is a patch available to fix this also.
Please let me know how you get on.
Feb 26, 2008 | HP PSC 1210 All-In-One InkJet Printer
77 people viewed this question
 Grubhead
Grubhead
