Question about Indesit Washing Machines
The Indesit washing machine WD12xUK- doesn not switch the programs from one to another. this means that if I put the linnen in and switch the machine on for, say, program 4 it will wash the linnen FOREVER without switching to the next program (rinsing, drying, etc.). OR the programm switcher (round thing you use to choose the programm) start ticking all way round. what is this?
  • 1294 Answers
SOURCE: My Indesit won't advance, won't complete a cycle
Suggestion: Try cleaning your outlet filter. This needs periodic cleaning, according to your usage. Refer to user's manual re. the cleaning. When it is the rinse problem it usually is the filter block. W
Posted on Oct 05, 2007
  • 209 Answers
if the drum rotates at any point and it empties with the pump at any point then check the heater element, its a common fault on these machines
Posted on Oct 07, 2007
  • 1462 Answers
SOURCE: my indesit washer/dryer model w10
probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Posted on Jul 05, 2008
SOURCE: not sure whats wrong with my washing machine!
My washer humes like it wants to start but doesn't and i have to constantly push it in an pull it out while its humming, after abot 15 to 20 times of doing this it will eventually start. Help!!!!!!!!!!!!!
Posted on Aug 04, 2008
  • 1462 Answers
SOURCE: The programmer on my indesit
this means you have a fault in another item
check heater is ok and check pump is ok and filter not blocked
Posted on Nov 27, 2008
What does code F-10 means?
F10 is a pressure switch fault which could just be the pressure chamber is blocked and needs cleaning out
use this link for error code Domestic Appliance Help
Oct 03, 2016 | Indesit Washing Machines
Indesit wil 153 door red led is flashing after I set washer settings, doesn't start cycle ?
The flashing light means that the machine thinks the door is not closed (The door lock switch is not activating). 99% of the time this is simply a sticky switch and the solution is to give the door a good firm slam shut (Don't get silly here, but it will take a pretty good "teenager slamming the bedroom door in a temper tantrum" type slam).
In the event that this doesn't work, then you're looking at a faulty door interlock switch. They're not that hard to obtain or fit if you're fairly confident. Drop me a comment back here and let me know how you get on. Happy to help further if the above hasn't allowed you to solve the problem.
Aug 15, 2011 | Indesit W 123 Front Load Washer
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
What does f-05 on the screen mean
It means it's not draining correctly. You'll have to open it up to see if the drain hose is blocked, or just call a professional F05 on an Indesit washing machine means "Pressure switch jammed on trip"
As is often the case, knowing the error code is one thing, but findng the cause is another because error codes often have several possible causes. The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too. Finally, the Indesit washing machines PCB's can give erroneous errors where the fault turns out to be with the pcb itself. This makes things very difficult if you don't have access to replacement PCB's to try.
Basically, I would keep an eye on the washing machine and try it again. If it reoccurrs then clearly it needs sorting, but if it doesn't it might have just been one of those things.
Apr 30, 2011 | Washing Machines
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
Dear Sir my washing machine which is one year old started for the last couple of weeks todo unnecessarily noises and also it doesn not drain the water, showing code F05. WHAT TO DO? thank you!
Sep 28, 2009 | Washing Machines
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
