Question about Honeywell Programmable Thermostat Heater
Can't Program Clock for Honeywell RTH230B Thermostat
I just installed new batteries and went to program the clock by holding in the clk button but the hour, minutes and day all blink and I cannot change them. Help!!
  • 1 more comment
  • zitogp Oct 06, 2008
    I have the same problem. Installed new batteries and now clock readout continuously blinks and I can't stop it or change it.
  • samf56 Oct 09, 2008
    Same problem! It seems none can fix it?!
  • gregarious1 Jan 31, 2009
    I have two of these and encountered teh same problem on both - on one of the units I finally managed to get it into "set" mode, but have no idea how I did it as by that time I had been pressing various combinations of buttons and switches for 20 minutes. Honeywell's support site was worthless in resolving this....
After you set the hr, min, and day, press the mode button.
Posted on Dec 21, 2009
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
My rth230b temperature up and down control buttons are now not operable, ie they do not move any function up or down. whether it is a clock reset, or changing the temperature.
Verify your battery is good. Make sure it is in manual and not program by using the mode select button. Verify its set to heat. The first push will show the set temp. Push twice or more to change the temp. With that all said if it is still locked out you might have a short. If its been less than a year you can call the support number on your installer sheet and check for warranty info. I didn't see one in the instructions but to be safe make sure there is not a lock out feature too.
Feb 26, 2011 | Honeywell Programmable Thermostat Heater
I have model # rth230b and the clock continues to lag disrupting the program. i have replaced the batteries yet the problem persists. any thoughts? thank you
i always just replace it,, could go without set back fuction and run with hold feature, its a faulty chip and replacement is the cure
Feb 02, 2011 | Honeywell Electronic Programmable...
How do I get my honeywell system up and going?
for now, put switches on thermostat to hear and press the up arrow button to the desired temp. All your programed temps will take more explaining and it would be best you secure a owners instruction book from home depot. oif anything, buy thr same thermostat and either keep it or return it . I'd keep it regardless, read the pmphlet,program you heat and a/c before returning for refund. Don't destroy packaging and give them back everything. You will also need two AAbatteries. Good luck.
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
How do you program channel and set time on clock?
2001 - 2002 Models:
Press the "CLK" (clock) button until the time is displayed, then press and hold the "CLK" button for at least 3 seconds until the time indicator blinks.
While the time is blinking. turn the rotary encoder to increase or decrease the minutes.
Once you've set the clock it will automatically return to normal operation after 5 seconds.
Pre 2000 Models:
Press and hold the "CLOCK" button for 3 seconds until the time indicator blinks.
Press "PRESET 5" to adjust the hour setting.
Press "PRESET 6" to adjust the minutes.
Press "CLOCK" again to exit clock adjustment mode
Hope this helps.
And to set the stations get the station you want and hold down one of the buttons from 1-6 to progream the station. you need to hold the button for about 5 sec.
Jan 22, 2009 | Alpine CDM-7833
Honeywell thermostat RTH230B
Sound like you need new one... take a look on amazon ecobee3 Smarter Wi Fi Thermostat Remote Sensor. It's not worth repairing it..
Jan 06, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Programmable Eletronic Thermostat model RTH230B
There are so many products, we cannot help without the model no. Try typing 'Honeywell programmable electronic thermostat' into google and searching for an image of your thermostat, then get the model no. Then you might be able to get some help.
Dec 20, 2007 | Honeywell Programmable Thermostat Heater
I can't program my thermstat
go to www.honeywell.com. There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Need to set the clock
press CLK button to temporily display clock to set clock press clk > 2 sec use the left and right arrow to set hour and min
Aug 22, 2007 | Jensen KDC-9520 CD / Cassette Player
Heating & Cooling Logo
665 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
