Question about Sony RCD-W500C 5-Disc CD Recorder
COPT CD I DID EVERYTHING THE BOOK SAID TO DO BUT WHEN I PUT A BLANK CD IN THE B-DECK IT COMES UP BLANK DISC I KNOW THE WIRES ARE CORRECT CAUSE I CHECK THEM ANY HELP WOULD BE GREAT THANKS RICK
  • KASEY7 Oct 06, 2008
    OK ON MY CD RECORDER I HAVE 2 DISC TRAYS TRAY {A} IS FOR THE ONE YOU WANT TO COPY TRAY {B} IS FOR THE BLANK CD TO COPY ON NOW ACCORDING TO THE INSTRUCTIONS AS SOON YOU PUT THE CD"S IN IT SHOULD SAY " TOC READING " THEN SAY NEW TRACK AND THEN START RECORDING THE PROBLEM I AM HAVING IS THAT AFTER IT SAYS "TOC READING" IT GOES TO TO BLANK CD
    OK ON MY RECORDER I HAVE 2 CD TRAYS ONE IS TRAY{A} THE OTHER IS TRAY {B} TRAY A IS WHERE YOU PUT THE CD TO COPY TRAY B IS WHERE YOU PUT THE BLANK CD TO COPY TO NOW ACCORDING TO THE INSTRUCTIONS WHEN YOU PUT THE CD"S IN IT SHOULD SAY "TOC READING" THEN SAY NEW TRACK THEN START RECORDING MY PROBLEM IS THAT AFTER IT SAYS TOC READING IT DOES'NT SAY NEW TRACK BUT IT SAYS BLANK CD HOPE THAT EXPLAINS IT BETTER NOW IF YOU CAN TELL ME HOW TO MAKE A COPY OF A CD MAYBE I NOT DOING SOMETHING AND THAT MAYBE THE PROBLEM
    Genius:
  • 2,035 Answers
As soon as you put a new blank disc in the player tray B it should read,TOC and blank disk ,after this insert the which as to copied in tray A and then choose the make disk ...Please use this link to get a manual
http://www.docs.sony.com/release/RCDW500C.pdf and refer 26...and start recording ,its normal to display blank disc if its a new disc....
Good luck...
Posted on Oct 06, 2008
    President:
  • 1,952 Answers
Click this link down load the file use itpages32to37
Disc Recorder','docs.sony.com');">http://www.docs.sony.com/release/RCDW500C.pdf
    President:
  • 2,712 Answers
Try switching the discs around and see if that works..ie, blank CD in tray A and original in tray B (just to isolate wiring issues).
You could also try using a different brand of CD's..
    Brigadier General:
  • 6,966 Answers
Your concern is rather common (and known issue) on this particular brand/model.
Things that you could try:
  • use a lower speed blank disc;
  • use another brand of blank disc;
  • use a lower recording speed;
  • use the One-Touch Synchro recording to check if the recording indeed works;
  • clean the lens of the recording B Deck. (Use CD disc cleaner similar to those used in PC CD ROMs);
  • avail of the 2 years parts and labor warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Oct 06, 2008
    or it could be that lens of Deck A needs a bit of cleaning as well
  • Sony Master
  • 6,487 Answers
Did yout tyry putting a different CD and check if this is only a problem with that first CD that you try to use??
  • 69 Answers
I think you just answered your own question... Did you say that when i you put in a blank disc, it says blank disc? Thats correct. And whats is a B-Deck?
Unit won't play discs,orig or otherwise. Keeps flashing "no disc" although they are loaded.
If the deck in question wont read/play any disc, blank or pre-recorded, try cleaning the laser lenz.
Apr 04, 2014 | Philips CDR775 2-Disc CD Recorder
The manual instructions are terrible! I can't figure out what should be showing on the display I am recording cassette to CD - Used cord output from headset to analog in recorder. Pushed the buttons as...
I don't know but you really need to evaluate the 'blank CD' assessment better. That is the proper indication that you CAN record on it in Deck B. See page 22.
Maybe follow the manual as written. For your analog recording scenario see page 25. Doesn't your cassette deck have RCA out?
The actual source is irrelevant to the "blank disc" question.
Mar 24, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Plays fine on both decks, but does not record in any mode.when press rec, the indicator switched from saying "blanc disc" to "data disc" i got this deck used last year. not sure if it...
Check if the blank disc you are using is compatible. It sounds like the discs you are trying to record onto are not compatible with the unit OR you are trying to record in the wrong mode (Synchro v direct see below) It will only record onto CD-R or CD-RW discs. Also read the instructions for recording as there are a number of recording modes depending on menu settings.
See manual here http://www.google.co.uk/url?sa=t&source=web&cd=2&sqi=2&ved=0CCMQFjAB&url=http%3A%2F%2Fmedia.zzounds.com%2Fmedia%2FRCDW500C-be7b6d8b3a46898dae1be148e1af5402.pdf&ei=3eIsTcisNI7sOce8hakK&usg=AFQjCNGCxcLKQKViw1TVJPh_baxuXkVKQA
Jan 11, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Problem with Sony RCD-W1 CD recorder
Are you copying a disc you have previously recorded? SCMS will prevent this.
'No disc'on the CDR deck usually means the laser is faulty.Can you hear it spin the disc? When you open the tray has the disc been rotated? The sony's laser is usually reliable. Sony US may have a fixed price repair or you can have a look yourself. I have the service manual should you need it.
Feb 14, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Formatting discs
Once the disc is FINALIZED, theres no way for the data to come off. If oyure burning from a computer, make sure you burn as DATA or AUDIO disk.......if the radio is MP3 compliant, then mp3 discs should work. The upside to mp3 discs is you can fit endless hours off music, but you loss sound quality from the compression.
CDs dont need to be "formatted" like hard drives or floppy discs. It's format is knows as red book, orange book......depending on the quality and manufacterer of the media.
If you have cheaper cds, like SONY, they can be problematic. Try TAIYO YUDEN or Microboards if you can get your hands on them.
Keep me posted.
Oct 27, 2007 | Maxell CD-R 80 Minute 700MB Media...
'No audio' comes up when you use the wrong type of cdr in the drive. You need a 'consumer audio' or 'music' specific CDR and not a generic computer cdr to use in these units.
Sep 27, 2007 | Marantz CDR631 CD Recorder
Recorder not recognizing blank media
To fix this problem, buy CD-R Blanks with word MUSIC CD-R MUSIC
Aug 28, 2007 | KLH CDR2000 2-Disc CD Recorder
I can not get my CD recorder to record
You should use consumer cd's that are rather expensive. You probably tried to record a recordable cd-rom (a cheap computer disc). It's not possible to burn a pro-disc (computer disc) by using your Pioneer, and that's why you got that message on the screen. Refer to the user manual of your cd recorder and learn what sort of blank cd you should use.
Aug 05, 2007 | Pioneer PD-R555RW CD Recorder
Sony RCD-W500C 5-Disc CD Recorder Logo
160 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
