Question about Roper MHE14XKB Microwave Oven
F6 error... microwave not working
We had to change our light bulb for the first time in about 3 yrs...we changed it, it popped the bulb and burned it out in just a few weeks... now we tried to replace the bulb again and when we went to turn on the bulb to see if it's working... it's not... any button that is pushed has the thing making a low hummmmm --- light doesn't work, fan doesn't work. Unsure what happened. it's MHE14XMQ product which does not show up in the box below as valid.
  • SprocketHead Oct 13, 2008
    I have the exact same problem. I replaced the light bulb and it lasted about 2 months. I replaced it again and now I have the same symptoms.
Is the microwave itself working? because same thing happened to us apparently the guy who changed the bulb didnt unplugg the thing first and well it burned a part of the circut board cost us about 90 dollars to fix it.....
Posted on Oct 12, 2008
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
When changing the lightbulb under the over the range microwave oven I heard a pop sound and now neither of the lights or the fan won't work but the microwave and the clock on it still works, it is just...
probably caused a short while replacing the bulb(s) and, causing damage to the circuit board. pull the board out and carefully check for burned foil traces; and rebridge with solder. it may or may not work. always unplug the microwave when replacing the range lamps.
Aug 06, 2011 | Hotpoint RVM1435 Microwave Oven
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
My microwave cooktop lights keep burning out. why? i've changed the 10 watt low volt bulbs 4 times in the last 6 mos. each time being careful not to touch the bulbs with my fingers. they will work for...
Are you keeping them on all the time?
Or is the the microwave subject to excessive vibration or door slamming while the lights are on?
Both these conditions are factors in premature bulb failure.
I would also avoid cheap Chinese bulbs from grocery stores and get the GE-specified bulbs either from here online or a local home center such as Lowe's or Home Depot. etc.
Dec 13, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light doesn't work on my over-the-range microwave oven
Absolutely. We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
Mar 13, 2009 | Microwave Ovens
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
Model JVM130G
what brand is this and did the light go on when the door was opened before you changed the bulb?
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Roper MHE14XKB Microwave Oven Logo
264 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Mark Cheong
Mark Cheong
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
