Question about Vacuums
DYSON DC07 ANIMAL VAC: IT SHUTS OFF INTERMITTENTLY, GETTING WORSE SURE ITS AN OVERLOAD PROTECTOR IN MOTOR. HAVE THOROUGHLY CLEANED THE UNIT TO NO AVAIL. HELP ???
    Master:
  • 479 Answers
The circuit tracks should be getting cut somewhere in between some where so it leeds to this problem.
Posted on Oct 05, 2008
  • tech gurus Oct 05, 2008
    the tube would have got clogged, so the engine had to work harder. This led to the engine getting hot. I guess they have a sensor of some sort, and when it gets too hot, it shuts itself down. So if this happens to you, here's what to do.
    1 - Look for the clog in the hose and remove it.
    2 - Wait. According to Dyson, it can take a couple hours for the vacuum to reset itself. There is no reset button, so you just have to wait for it to cool down.
Hi, I have had my Dyson DC07 Animal vacuum for 5 years. Recently, it turns off by itself while vacuuming. Perhaps it is overheating. But this does not seem normal. It is not being used as an industrial...
Try this:
I don't know how many filters the Dyson has, but my bagless has three.
Take all of your filters out and inspect/clean them. Many vac's have thermal overload switches in them that can only be reset by them cooling. This is probably what is happening. One of the filters is not allowing sufficient
air to pass.
Gary
Feb 10, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
The motor on my Dyson Animal DC07 is getting very hot. I've always kept the filters and such clean. Is there any maintenance I am to be doing with the motor?
Hi its Darran at Dyson.
From your description of the problem, it sounds as though there is a lack of airflow to the motor which is caused by a blockage in the machine or a dirty filter.
To check your machine for a blockage, please refer to your user guide or visit the support section on our website at www.dyson.com. It is worth checking that both parts of the filter have been thoroughly cleaned.
If you are still experiencing difficulties, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 motor does not come on. Hoses are
depending on where you take the unit. the motor is about $60 or $70, shop time at a vac shop is going to be about $40 to $50. The whole thing will run you about $150. you can go to the Dyson web site and find a service center.
Oct 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson dc07 animal has lost most of its sucking power
You may have a blockage somewhere in the machine. Call the Dyson helpline, they'll walk you through a blockage troubleshoot.
Jul 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Noises in my dyson
clean it up thoroughly and then grease it with lithium grease from an auto parts store.
Jan 26, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Animal
Obstruction in the hose?
Your vac has developed a hairball possibly.... when a piece of flexible media ie.... cardboard, plastic etc... gets lodged in the hose, and begins collecting hair & dust to the point it no longer has enough draft to pull debris from the floor.
Here is a video that you may find useful
http://video.aol.com/video-detail/dyson-not-picking-up-dirt-no-suction-how-to-repair/2334249387
PS I Thought DYSONS were guranteed to NOT lose suction? What a RIP!
Jan 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson animal vacumn refuses to pick anything up, even a tiny piece of lint?????? It was working fine for awhile. I paid $500.00 for this cleaner at Target because I have 4 inside cats.
remove the vacuum debris recepticle and pull up on the filter cover..
You can:
1. quick fix..use a SHOP VAC and vacuum it thoroughly replace
2. wash and dry thoroughly and replace should fix problem
...I have a spare filter to use while other is drying..you can purchase off the Dyson site..
Caution be sure filter cover snaps shut before using
Dec 29, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson animal
Is the noise a loud screaming or a grinding/vibration? The screaming is an air flow problem and you'll want to check your hoses are clear and all the seals are tight. The grinding is an issue with the roller/belt/clutch/motor/housing. From what I'm reading, both problems are common on the Dyson animal.
Sep 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07
First, check all of the ports, there are various covers you can take off to see if there is a clog, also check the hose for a clog. Make sure all filters are clean out. The worse case would be a motor problem.
Feb 14, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson noise.
Check all ports for a clog, there are removable covers you can take off, also check the hose for a clog. Make sure all filters are clean. Worse case is a problem with the motor.
Jan 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
