Question about Xerox Phaser 8500/DN Printer
Cyclic reboot My 8500 makes it through the POST tests fine, says the tests are complete. Next it says it is Initializing.... but this stays for a couple of seconds then power goes off and reboot starts again. I never hear any motors turning during this process; only the fans turn own to cool the power supply.
  • Anonymous Oct 23, 2008
    me too
    Scholar:
  • 49 Answers
When the machine is powered on just check if it is warm under the top flap! If not the lamp is broken if it is warm you need to clean the temp sensor under the top flap. Either way the problem is because the machine is not reaching the right temp to operate properly! You will need an engineer to replace either the lamp or sensor, so call Xerox customer care or the shop were you bought it! Do you still have a warranty?
Niallbt
Posted on Mar 30, 2009
I hit a pot hole and my battery died the next morning. I got it tested and it was bad. I bent both right side wheels after hitting a pot hole. My car won't stay charged. Active steering is off too.
I would check all earth wire on your car , as it sounds if there is a bad earth wire or a broken one ., this would explain your battery going flat and the flat battery would probably cause your problem with the steering as it will probably be an electric steering pump
Jun 29, 2015 | 2004 BMW 545i Touring
When i turn on my printer it says (system initializing) why
"System Initializing" means the printer is going through it's startup process. If it hangs, it usually means something is wrong with the printer.
Make sure all printer cartridges are seated properly and securely. Make sure the paper trays are pressed all the way in and locked into place, make sure all doors on the printer are closed and latched properly.
Unplug the printer from power completely and wait about 30 seconds. Plug the printer back in and power it on without being connected to a computer or network cable (if applicable since you did not post make / model)
If the issue continues, the printer may be faulty and need serviced or replaced.
Nov 13, 2014 | Samsung Office Equipment & Supplies
System Initializing
Have you tried unplugging the monitor from the 120 volt supply for a minute or two then replug and turn on. Like computers and some flat panel TVs they can freeze-up after an unplanned power loss and need rebooting
Jan 12, 2014 | Samsung SMT-190 19" Flat Panel TFT LCD...
My player stays on the opal initializing screen
ele nao ta ligando so assim initializing
Jun 26, 2010 | RCA M4204 MP3 Player
GeForce 8500 on Intel DG35EC no display
Make sure the card is seated all the way in the slot. And the slot is clean, also check the power plug if it has one.
Aug 23, 2009 | ASUS GeForce 8500GT Graphic Card
Xerox Phaser 8500
Entering Service Diagnostics without Rebooting the Printer:
This method of entering diagnostics is to allow customers to be diverted to service
diagnostics in order to perform some tests.
1. Display the Hidden Service Menu as described in "Hidden Service Menu" on
page 4-2.
2. Scroll down to Enter Diagnostics and press the OK button.
Entering Service Diagnostics by Rebooting the Printer (8400):
1.
Turn the printer power OFF.
2. Press and hold the Back and Help buttons.
3. Turn the printer power ON while continuing to hold the Back and Help buttons
for approximately 30 seconds until the Control Panel indicates Diagnostic
Menu
Entering Service Diagnostics by Rebooting the Printer (8500/8550):
1.
Turn the printer power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold the
Back and Help buttons on the Control Panel.
4. Hold both buttons until the display reads Beginning Service Mode
Initialization
. Release the buttons and the printer reboots into service mode
with the Service Diagnostics menu displayed.
May 23, 2008 | Xerox Phaser 8500/DN Printer
Dell memory Dimm B errors, 2 gig memory upgrade
Can your laptop support 2 gigs?
Also, are you using the right memory for your laptop?
Nov 15, 2007 | Dell Inspiron 6400 Notebook
Xerox Phaser  8500/DN Printer Logo
174 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
