Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Homelite chainsaw carb adjustments
I have 2 homelites. models 10660A and 10661A. What are the high and low speed adjustments?
  • 2 more comments
  • bear973 Oct 09, 2008
    I have a 45cc power stroke timberman 45- It runs great for 2 min. then slows down .if you tilt it down it runs bad or up to much. I can turn the carb screws while it's running & it takes off & runs great for a min. no amount of adjusting will keep it running at max rpm.I tried putting the fuel pick up in different locations, no help it seams to run better as long as the tank is completely full.
  • Cannonball56 Oct 15, 2008
    Still looking the answer to my question. Don't know who bear973 is or how their question was attached to mine. Does anyone out there know the answer to my question on Homelites?
  • smeds090 Apr 01, 2009
    I adjust the carb and it runs great and strong for a long time, then suddenly it dies and is hard to start. I wonder if the chain is too tight. But I loosen the chain tension and it doesn't help. So my problem isn't too much drag (load) on the engine. I wonder if I just simply have to rebuild the carb.
    I've cleaned the tank and the line is good. I've had the "bad-line" problem before. Of course I've reset the carb-adjust limiters. I'm pretty thorough, so I guess the next step is to rebuild the carb. After all, if I took it to a shop, they could get it running so it would maintain its integrity... So why can't I?
    To those who have tried replacing the fuel line and dealing with the filter, try rebuilding the carb. Make sure to spray cleaner through all the ports and passages, the blow compressed air through afterwards. Reassemble and adjust as needed, using the new rebuild kit of course. Let it warm up and readjust as needed. Also keep in mind to have the air filter installed before making adjustments. Everytime you adjust any carb, you must do so as though it were going to run daily, with all components installed.
  • Anonymous Mar 17, 2014
    High and low speed adjustments on blue max chainsaw carbs
Bear973 you must make sure that that in tank filter is seated in right position and not just floating around inside the tamk
Posted on Mar 24, 2009
  • 4 Answers
How about a new set of rings?or a crankset with new piston etc?could be just worn out on other 2 strokes you have to get new rings every so often,and decarbonize,at or around 500 to 1000 hrs ,a couple of wrongly mixed tanks of fuel will shorten life of the rings
Posted on May 04, 2009
I'd replace the fuel pickup and line. It sounds like you are getting air into the fuel system ahead of the carb.
Posted on Oct 14, 2008
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Why does homelite chainsaw runs wide open?
if your saying your saw runs full speed as soon as it starts , one of two things is happening :
(1) your low speed carb jet is too far open
(2) your throttle trigger has disconnected or become stuck from your carburetor and now the throttle blade inside carb is full open
Jun 15, 2014 | Homelite Garden
I have a home light super 1050 chainsaw runs rough how do I adjust the carb
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj
Apr 01, 2013 | Homelite Garden
Homelike chainsaw carb settings high/low
Hi, most chainsaws start with carb settings at 1&1/4 turns out( hi+lo) usually once the chainsaw has been run in, the 'hi' screw can be turned in an eighth, tickover set low enough not to cut out but high enough not to engage the clutch, cheers Billy
Feb 15, 2013 | Homelite Garden
Adjustment on high and low speed screws ?
http://www.aerocorsair.com/id150.htm
Look down this website until you come to teh Carb Tuning section.
Aug 24, 2012 | Homelite Garden
Fuel adjustment on a homelite chain saw ut 104002
Hi Alex Sachs
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Aug 21, 2012 | Homelite Garden
I have an older homelite super ez chainsaw with a carburator problem. What is the proper adjustment for th two setting screws on the sie of the unit? I believe one is high speed adjustment and one is...
In side linkage plate thers a screen may b clogged, check this before adjusting carb. if carb needs ajusting turn in but dont over turn, back out 1/4 turn at first but no more than 1/2 turn.
Sep 01, 2011 | Homelite Garden
I have an old homelite super xl saw and what i need to know is the high and low adjustments as well as spark plug gap
For the high and low speed jets turn all the way in and turn counter clockwise 1 1/4 turns to start with and continue a bit more until the saw runs a max speed(go by ear) and idling speed(idle down enough so chain does not spin while finger off triger). For the spark plug gap, go about 20 thousands of an inch. I hope this helps you out.
Jul 15, 2011 | Homelite Garden
What is the high / low carburetor adjustments and the fuel mixture for the UT21566 Homelite trimmer
Hi dcheddy...
If you have tried to adjust them already then this should get it running...then do your final adjustment when the engine is warm.
Free Answer...Please take time to rate me
Jul 09, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
2,657 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
