Question about Emerson Smartset Clock Radio
Emerson Jumbo Display CKS2237 clock radio
After a power cut the radio will not turn off and the display shows 'SL'.
We have put the sleep mode to a minimum of 2 minutes but the radio continues to work.
We have tried to reset the time but the time is correct when we press Time and Date/Month together.
The 'Battery Low' is not showing.
We have switched off the main power but when we switch it back on the radio continues to play and the display shows 'SL'.
Can you please advise? Thank you.
LINDA LUKE
    President:
  • 814 Answers
Sorry it took so long to get back to you with a answer to your question. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
I would like to buy one
You can order them directly from emerson.com or go to Walmart, Circuit city. or best buy and find one.
Jan 20, 2011 | Emerson CKS2237 Clock Radio
Lost my manual and cant figure out how to set the time. Any help out there. Thank you
From the user's manual
Setting the Clock
1 Turn the Mode control until the clock icon is highlighted
with brackets .
2 Press the Mode control. The clock icon and time display will
flash.
3 Turn the Mode control to adjust the time.
4 Press the Mode control again to set the time. The display
reverts to its previous mode and the new time is set.
Note: The clock can display time in either 12 hour or 24 hour
format. To change the time display turn the mode control to
highlight the clock icon with brackets . Press and hold the mode
control for 5 seconds. The display will show “12H” or “24H”. Turn the
mode control to select the time format you want, then press the
control.
Mar 08, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
LED Dimmer on Emerson CKD 9901
On Those Clocks No You Can't
I Normally put a shirt over the led screen light that way i can sleep hope ive been helpful to you
Jul 17, 2008 | Emerson CKD9901 Clock Radio
My Clock Gains Time
The Clock Is Faulty if you have warranty on it take it back
Jul 05, 2008 | Emerson CKS2237 Clock Radio
Emerson Radio CKD9906
I hope this will help you, I just found the Users Manual to this Model online myself, as I needed info on setting the Alarm.
I am also going to upload the full Manual, just incase anyone else needs it.
Cheers!
Peachess
Setting The Time Of Day
• Connect the power cord to your AC outlet. Make sure to use an outlet that is
always ‘live’. Do not use an outlet that is controlled by a wall switch.
• When the unit is plugged in for the first time the
display will show flashing “12:00” (AM).
1.) While the display is flashing, press the HR. button to set the hour. Be sure
to observe the PM indicator to set the hour correctly. If the PM indicator is ‘On’
the hour displayed is PM.
2.) Press MIN. button to set the minute correctly.
3.) Press the TIME button once. The time is set.
The display remains ‘On’.
Note: You may proceed to re-set the time again by pressing the TIME button
once during Power-off or CD, FM, AM, Buzzer modes.
Important Notes !!
If you press and hold the TIME button any time, the clock will change to
European 24-Hour format, and 12-Hour USA format.
May 10, 2008 | Emerson (CKD9906) Clock Radio
Emerson research smartset cks2237
http://www.emersonradio.com/owners/SmartSet%20Series/CKS2237_073106.pdf Copy this link and paste it into the address bar of your browser. It will take you to the users manual for the model CKS2237 clock radio. On pages 7-10 you will find the instructions for setting the time for the clock. I hope this information helps you solve your problem.
Apr 29, 2008 | Emerson Smartset Clock Radio
Lost instructions for Emerson
to change the alarm mode setting for alarm 1, hold alm1 setting button and press the alarm mode button until the day indicators show thedesired mode setting. weekday only,weekends only,or everday operation. release the alarm mode and alm 1 setting buttons and the display will return to correct time.
Dec 05, 2007 | Emerson CKS2237 Clock Radio
Time is wrong
Sure. p.7 in the user guide: http://www.sonigem.com/uploaded_files/manual_archive/CKS2237Ceng.pdf
Dec 09, 2005 | Emerson CKS2237 Clock Radio
Emerson Smartset Clock Radio Logo
114 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
