Question about Lexmark X1270 All-In-One InkJet Printer
Stooler problem my system said that I need stooler service because it doesn't run
    Novelist:
  • 169 Answers
I believe (and hope!) you're referring to a "spooler" error.
Here's what you need to do:
- click on "Start, Run"
- type "services.msc"
- when the services window pops up, on the right side, scroll down until you see "Print Spooler" then double-click on it
- if the service is not set to "automatic" via the drop-down menu, select that option
- if the services is not started, click "start". If the service has started, click "Stop", wait for a few seconds and then click "Start" to restart the print spooler service.
You might have to reboot after this (a good idea anyway) and you should have no more problems. If you run into continued print spooler problems, you either have spyware/virus damage, or corrupted Windows files (the latter requiring a Windows repair or reinstall)
Hope this helps - remember to rate :)
Scott
Posted on Oct 06, 2008
My bajaj pulsar220F doesn't have enough pick up as before and its only been 6 mnths dat i purchased,Even i have done timely servicing
I'm assuming your talking about the batteries. You can purchase more batteries and put it in parallel to your existing batteries. it will give you longer run time.
Sep 07, 2011 | Computers & Internet
Hi My computer doesn't have IIS (Windows XP).Is there anyway i can add? thank you
You don't need it. It an internet server app and XP Home doesn't have anything to do with it. It runs on Windows Server software.
Aug 11, 2011 | Microsoft Windows XP Home Edition
Engine turns over, stalls out and alarm goes off
These vehicles use Fords Securilock transponder system to prevent vehicle theft. Basically, there is a little radio chip in the key that transmits a code to the computer when you start the car. If this code doesn't match the computer, the computer disables fuel and spark so the engine won't run. If you have a spare key, try that to see if it works. If it doesn't work, then the Securilock system needs service. Unfortunately only the dealer can service this system because it is integrated into the vehicle computer.
If your spare key works, then the key you tried to use has a damaged transponder and the key needs to be replaced. If you don't have a spare key, contact a locksmith and have them make you a new key. I have to warn you, transponder keys are not cheap. They can cost easily $75 and some even go for $150. But, that is probably cheaper then having Ford make one and even if the spare doesn't work, when you get the system fixed by the dealer they can program your spare key as well so you don't waste the money on the key.
Aug 11, 2011 | 2000 Lincoln LS
I just bought last week whirlpool refrigerator from best buy.week past allready and the fridge doesn't make cold water for drink water is warm and taste strange what is wrong with it?since i have...
Before you call for severcie you should run about 1/2 a gallon of water through the system to make sure the it is cleaned out and no air bubbles in the system. But if you do that and it still doesn't correct itself, then YES - call for service.
Aug 07, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cannot find URL http://192.168.1.102:8080/ on my computer network.
hi,
well to find an :8080 a device has to be running a service on that port. so I suspect you had a service running which is no longer available on the IP in question.
so first is, where do you see this error and do you have a computer on your network with the IP of 192.168.1.102? as this could have been working at one time but . if you didn't reserve each network device to a number. then it is possible for each device to get various numbers each time they boot up. hence the system you want doesn't have that number anymore.
it is best to go on the router and Identify who has what number and reserve them. so that scheme doesn't change.
GL
hope this helps
please don't forget to vote for me
Thanks
Jammer
Jul 11, 2011 | Computers & Internet
On my desktop ,after booting my gadgets doesn't display ,and my system is alwayz slow,please i need solution,even my battery,when you plug in the adapter it would say not charging 12% plug in,and my...
With the battery running that low and not accepting anything you will need to consider buying a new charger, as for the system is running slow try un-installing all un-wanted programmes from your computer as this is taking up space and processing power, run a De fragmentation on your hard drive which can me done by double clicking on your My computer then Right click your C Drive and going to properties then click on de fragment with will speed up your system a bit, delete all un-wanted films, pictures and music will also speed up your system
Jun 27, 2011 | HP Pavilion dv6000t Notebook
HI, my maxtor basic 500 Gb doesn't start in Windows 7. After plug it , the SO doesn't see it. Can you help me?
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jun 21, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
Printer spooler services not started when i connect to network printer cannon lbp 2900
There are several ways to resolve printer spooler error, probably because there are many variations of this error.
The error caused by faulty software can be resolved by deleting all the information found in the directory.
Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon.
Find the service labeled Print Spooler, highlight it and restart the process. If that doesn't work, the program
might be corrupted.
Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another
window.
On this window, scroll down and click "Print Spooler". Check its setting and turn on automatic mode.
Click Okay, and restart the machine. If you're lucky, this might be all you have to do.
Still doesn't work? Navigate to the Add/Remove Programs screen of the Control Panel.
Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure
to be thorough about it, or the problem may not be solved.
Download the latest copy of your printer's software from the manufacturer and reinstall it.
May 09, 2011 | Canon LASER SHOT LBP-2900 Printer
Cannot open my yahoo messenger
you might need to uninstall the program, and reinstall it one more time , pls go to yahoo's website and install the latest version.
it could be corrupted
http://messenger.yahoo.com/
Aug 14, 2008 | Yahoo YHT-630 System
Lexmark X1270 All-In-One InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
