Question about Philips 60P8341 60" Rear Projection Television
IS the philips 60P8341 HD? - Philips 60P8341 60" Rear Projection Television
    Genius:
  • 1,148 Answers
Yeh its a hdtv,,
Posted on Oct 05, 2008
60p8341 fuses
TRY MCM ELECTRONIC OR ANY ELECTRONIC PARTS STORE IN YOU AREA JUST TAKE THE FUSE WITH YOU
Apr 21, 2012 | Philips 60P8341 60" Rear Projection...
Where would i find a replacement remote
$40.95 at partstore
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips/60P8341/Royal+Philips+Electronics/Philips/312814712082/New.aspx
Also check www,replacementremotes.com
Sep 28, 2010 | Philips 60P8341 60" Rear Projection...
Philips HD/TV rainbows the picture at the bottom of set.
Hi, the convergence circuit is getting ready to fail, fix it NOW and you may get away with just resoldering the STK`s, soon they will overheat and short then it`s going to be 250-300 to fix it depending on your area rates, gl, video-tek
May 29, 2009 | Philips 60P8341 60" Rear Projection...
I would like to clean the inside of a philips 60p8341 projection
I just did mine, I used Denatured alcohol on the top of the lamps and on the mirror. It worked very well. Make sure you use a soft cotton cloth. If it is really bad you may have to repeat. On the last cleaning make sure you go in the same direction to not have lines. Try to go in the same direction on all cleanings.
Mar 20, 2009 | Philips 60P8341 60" Rear Projection...
Question about Philips 60P8341 projection tv
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
http://servicemanuals.vstore.ca/
Sep 22, 2008 | Philips 60P8341 60" Rear Projection...
Model Philips 60P8341 60 inch
Most common problem for this is the Flyback transformer/trippler. If you would like to try the repair yourself let me know and I will help you. If not a repairman should charge you around $400-$500 for the repair. Let me know what I can do to help!
Tim Nolan
Sep 11, 2008 | Philips 60P8341 60" Rear Projection...
Service manuel
Does the led blink when it shuts down? and will it stert up again when you press power? Let me know and I can assist you with the most likely cause.
Aug 26, 2008 | Philips 60P8341 60" Rear Projection...
60" philips projection tv
HI I AM HAVEING PROBLEMS WITH THE VOLUME THERE IS NONE AND NONE OF THE BUTTONS IN FRONT OF THE T.V ARE WORKING HELP PLEASE
Mar 07, 2008 | Philips 60P8341 60" Rear Projection...
60P8341 Rear Projection - Remote does not work
Your TV needs the part 313501707611 - it's the keyboard that's the cause of your problems - but here's the catch... Philips does not make that part anymore... they say that you need to either find someone to fix the keyboard (which I've had no luck on) or buy a new Television from them... hmm, a $2000.00 TV that needs a $20.00 part now becomes a plant holder in my living room because Philips wants us to purchase a new TV from them.
Oct 06, 2007 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
