Question about Intel Motherboard
MSI 7041 Motherboard problem?
I am working on a generic computer which appears to have a damaged motherboard? When you switch the computer on the cpu and psu fans work, but it does not perform the POST or boot into Windows. There are no POST bleeps or signals to the monitor. I have tried inserting a VGA card, instead of using the onboard graphics card and have connected the monitor to it, but nothing appears on the screen in both these scenarios.
Any ideas what else I can try? Many thanks.
    Novelist:
  • 169 Answers
RAM would be my next guess. If the board is bad, so could the RAM be as well. Try swapping some known good RAM and see what happens. Or, at the least (if you have more than one stick), remove all but one and try again. Repeat until all sticks have been tried by themselves - you could just have one RAM stick causing the problem.
However, usually even if you have one bad stick, your system will still post, just show less memory. On the off-chance that all sticks are bad, then you might have similar symptoms.
Sounds like a bad mobo to me :(
Scott
Posted on Oct 06, 2008
I just bought a msi kt3 ultra ce computer with no drives. What drives do I need to get it running?
If you are looking for the motherboard device drivers then -
You can download the device drivers from MSI WEB supportsite, select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
Sep 09, 2011 | MSI MS-6380E (MS-6380E-010) Motherboard
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Are there drivers for the MSI PT880 motherboard that are compatible with Windows 7?
windows 7 has generic drivers to preload for your system ... also check msi for your drivers it supports
Dec 24, 2009 | MSI PT880 Neo FSR Motherboard
My vga is not working
If your motherboard VGA chip is not working or reported as faulty then you need a new motherboard.
Jul 26, 2009 | MSI COMPUTER K9A2VM-FD Motherboard
My driver cd is damaged
You can download the required drivers from:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Hope this solves your problem. Thanks.
Jul 14, 2009 | MSI K8MM-V Motherboard
MSI K8MM-V motherboard doesn't work after BIOS update
First of all never update or install the new bios.. plz let it be geniune .. another thing is that you have to now do the following which might help.. not sure but should
  1. Open the case
  2. look for the jumper on the mother board.
  3. when found take it out
  4. and the reboot or boot your machine
  5. then check if bios options and windows have started
  6. if windows does not appear then install new OS recommended windows 7.
  7. after this plug the jumper back into the motherboard back.
Now this won't work then it can posibly have damaged you motherboard...
Jun 23, 2009 | MSI K8MM-V Motherboard
Ethernet controller driver for MSI K9N6SGM-V motherboard
download it here:-)
http://driverscollection.com/?file_cid=24542326809xlelZKzpukYZUZoo
Nov 11, 2008 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Intel Motherboard Logo
138 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
