Question about Beko 324250WN 28" TV
Changing channels by itself
Hi.My tv is changing chanels by itself,more exactly from 99 to 01 and again and again...Not responding to remote control,but if I push and hold the chanel selector buton on the front of the tv and in the same time plug in the scart socket at the back,it's working as long as i hold the chanel selector buton.Many regards.
Are you using energy save globes . had trouble with those globes with my remote it effected signal from the remote.. get your remote tested to see if it is not continually sending signal or you might have dry joint on remote receiver
ben
Posted on Nov 27, 2008
Bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Posted on Nov 03, 2008
No turn Chanel's manual or with the control
If you have a newer television, the remote control that came with the TV might not change the channel if you are using a set top box. Try using the cable box or satellite remote instead.
Apr 06, 2014 | Televison & Video
Tv says receiver is not on and do not respond to remote control
Hi Jackiewes928, I apologize for the inconvenience you have experienced. It is my pleasure to assist you today. I understand that the only channel you are currently getting is channel 116 and that your remote is not responding. Do any buttons at the top light up on the remote when you try to change channels? If so, what button lights up in red or green? if any button other the SAT button lights up this means that the remote is not on SAT mode and this would be why is not responding. In order to put the remote in SAT mode press the SAT button for 3 seconds. Once you do this try using the remote. If you need further assistance please feel free to reach me directly at kimberly.escobar@dish.com
Feb 06, 2013 | DISH Network IR Remote Control
How to get chanels to be auto store on remote
Just do a channel auto search through the menu and channels should be memorized.
Nov 09, 2011 | JVC Televison & Video
Hello , My TV is 42PFL7422 LCD , The problem is oprating function change itselfs and also chanel TV with AV port. How to stop it Thank you
he problem of your TV is the button of the channel will not getting back so channel can't stop
you have to do is replace the button if you will or use a remote control to access the channel and never use manual changing channel again
Mar 09, 2011 | Philips 42PFL7422D 42 in. LCD TV
Channel button on remote will not change the channel, nor will the buttons for up channel or down channel on the side of the tv work. You can change channels only by pushing the number buttons. My dad has...
go into the menu of tv find the option to auto program- let unit go thru process without interupting it.now chanels up&down should work-the problem was there were no chanels in its memory
Sep 04, 2009 | Televison & Video
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Aug 08, 2009 | Televison & Video
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Once the TV is turned on, it immediately begins to flip from channel to channel by itself. Also, the TV no longer responds to the remote control.
check for a clogth chanel button, is very rare, but in the past, I solve this problem by changing that switch, is a job for a tech not for regular people remember, there are many dangerous circuit in a tv.....good luck
Aug 09, 2006 | Konka K2001UM TV
Beko 324250WN 28" TV Logo
234 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
