Question about E-Machines eMachines Desktop PC
Emachine 3623 boot up??
We had a fuse blow and in the dark somehow someone also pulled my electrical plug out of the tower it was not damaged but now my computer is asking for bootup disk and I don't have this anymore
Probley computer crash ,dont say what system you using try getting a onther copy of windows opeting system put in you cd drive and should pick it up, if not go into boot sequence in bios and d-drive your boot up first it should give you fresh operating system and maual load the drivers for your hardware manual if it has picked up
Posted on Oct 06, 2008
I can start my 1999 crown Victoria with spark plug #1 disconnected but, if I connect it, it will shut off and will blow the fuse
A bad plug boot or coil is shorted bend the boot back and forth it will show a crack or even break if it's to brittle if not that coil or the wire or plug is dhorted out look at the wire for torn insulation making contact to ground if not coils bad and maybe cracked letting the positive voltage escape to ground and blowing the fuse try to check it in the dark while someone cranks the engine the voltage leak will be seen as a spark
Nov 19, 2016 | 1999 Ford Crown Victoria
Why is my heated auto dimming driver side and rear view mirror getting dark when driving
Look in the fuse box for the fuse it will likely have other things on it but nothing to high voltage .
Pull the fuse and see what happens .
Honestly I have never heard of this .
Unless the mirrors lit or damaged somehow from to much heat damaging the coating on the back of the glass making it not a mirror any more .
This sounds like a factory defect
Feb 19, 2016 | 2004 Chevrolet Avalanche
How do i unplug big blue cord on tower emachine
You do have to unscrew the two screws on either side of the plug to remove the cord. Hope this helps.
Jan 01, 2014 | E-Machines eMachines Desktop PC
E machines w 3623 wont boot windows 7 fresh install
Did you check W7 compatibility before install? It is likely that your low-end RAM-based graphics was a bust.
Oct 27, 2012 | eMachines W Computers & Internet
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    I changed the NIC card in my HP pavilion and now my machine will not power up. It was working fine prior to this. Could I have blown a fuse or something? Any suggestions?
    While there isn't a "fuse" to blow, there are several things that could prevent your system from booting after making hardware change. However, there is a distinct difference between not booting and not powering on, and for further troubleshooting we'd need to know which is the problem. In the mean time, here are some things to consider:
    1. An incredibly small amount of static electricity can short your motherboard and prevent the system from booting at all. Whenever you do any time of hardware update or configuration change, always where an electrostatic discharge wristband to prevent damage to your system.
    2. If you somehow unseated the processor from the motherboard during your upgrade, then the processor would lose some of its ability to dissipate heat, which would cause an automatic shutdown.
    3. It is possible that you loosened a wire/jumper/plug that was integral to the boot system of your computer.
    Feb 13, 2011 | HP Computers & Internet
    Tower won't turn on
    hi try to put the monitor lead in the tower, the leads are both the same, the fuse might be out in the tower lead.
    Mar 28, 2009 | E-Machines eMachines Desktop PC
    Emachines T3410 won't boot, black screen, no cursor
    I had this same problem, none of the posters above have no clue what there talking about. With the K8M51gc MB, if the dust builds and then the system heats, it can and will blow a cap. Nothing you can do will make the board work again without replacing the cap and there are too many to test on the board and need an experienced tech to fix this problem as soldering the components are extremely small. Your best bet is to get another board from ebay and not emachines or gateway. Their site will charge $150 bucks when you can get it for $75 on ebay. You can also use a board from the T3304 as its the same system basically. It sucks I know but this would be your best bet as I had to go through this myself. If you decide to change out the board, run more fans in the system and use screens in place of the fan to prevent dust. Once every other month, use a can of air to blow out any dust on the board as duct can conduct electric through the board. Hope this helps...
    Nov 15, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
    I have a emachine w5243 tower the expansion drive won't open.push botton but still know
    the expansion drive will open if you can hang a fingernail or something thin in the top of the door and pull. It only takes a gentle pull.
    Mar 29, 2008 | E-Machines eMachines Desktop PC
    Emachine W1135
    when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
    Oct 17, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
    E-Machines eMachines Desktop PC Logo
    85 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
