Computer monitor started smoking,now doesnt work,its only 30 months old.will warranty cover it???
  • 749 Answers
Most monitors these days only carry a one year warranty. some of the higher end ones are longer. it would be worth the effort to at least check into the warranty. if its not still covered , trash it, use it as an excuse to get the monitor you really wanted. you can find a 22 inch monitor for under $200 all over the web.
Posted on Oct 06, 2008
My HP 2711 monitor went white. I plugged in another monitor and everything works fine on my computer. Ive only had this monitor and computer for 2 months so it should be covered under warranty. i guess the...
Hi, yes this monitor should be covered by a warranty, my advise is to return it to the vendor and ask for a replacement.
These things die like files as the saying goes. But HP are real good with warranty usually simply make contact with HP and ask them what to do, and be guided by them if the vendor isn't helpful.
Sep 10, 2011 | Computers & Internet
I have a 25" Hannspree monitor which is only about
No - the buzzing you're hearing is probably the inverter transformer. Its' purpose is to generate high voltage to turn on the backlight to display the image on the screen. The monitor should still be under manufacturers warranty since most of them are a year. Have it repaired or replaced.
Feb 14, 2011 | Hannspree HH251H 25" LCD Monitor
My monitor has gone from a beautiful, sharp screen to one that is faded and blurry. It is only about 6 months old. Is there an adjustment that can be made?
Hello Katherine ann, hi, the faded and blurry picture is usually caused by poor LCD panel connections, due to loose contacts and screws. This is usually poor ventilation, or factory defects. Since you mention its only 6 months old, it is still cover for warranty, call your dealer for service.
Mar 24, 2010 | Acer 22" X223w LCD Monitor
Thin purple lines started appearing on aoc monitor. Computer is Acer Aspire, quad-core with integrated video. All connections appear to be tight. Lines are going further upward now. jscreenfix isn't...
well this could be one of two things it could be your monitor so get it checked at a freinds house if that works fine at your freinds house then it must be your graphics card if the monitor is the problem then yes its a warranty issue and should be replaced by supplier if its the graphics card and its not covered in your warranty then you should be able to get a cheap one on ebay hope this helps
Mar 13, 2010 | Computers & Internet
Hi, my 9 month old emachines monitor keeps turning off by itself, sometimes as much as five or six times a minute, otehr times not for 30 minutes. Any ideas?
Sounds like its the motherboard that is failing.
Since it's only 9 months old it should still be under warranty.
This computer will need to be taken in for service and the motherboard replaced.
Sep 27, 2009 | E-Machines eMachines Monitor E15T4
Bezel
the front bezel for the computer of the monitor?
if it is the computer, it contains power switch, USB port.
if it is monitor, then it is just cosmatec.
if you are curize, call gateway and find out if they the item in stock or on back order.
gateway web site is: http://www.gateway.com/about/contactus/index.php
phone number is: in warranty: 866-539-3901
out of warranty: 800-229-1103.
Good luck
May 15, 2009 | Gateway Computers & Internet
Blue tint...then unresponsive...only 5 months old
You're probably lucky that this happened now. You're most likely still covered under warranty. Contact Acer support and arrange a swap. If your pc works okay with another monitor there's no point in troubleshooting further. Get that monitor switched before the warranty runs out.
Apr 27, 2009 | Computers & Internet
MY MONITOR DOES NOT WORK
Is your computer recognizing the monitor?
Have you over looked something simple , like turning the monitor on?
We are human and tend to sometimes over look the most simple thing, If that does not help there sould be a hot line to call for help with your computer
Jun 04, 2008 | X2Gen MG19MY 19" LCD Monitor
My 4 month old laptop is not working
If the monitor turns black - maybe you have a screen saver or there is a fault with your display. Try using an alternative monitor or flat panel.
What do you mean by blockt?
Mar 12, 2008 | Computers & Internet
Something wrong with my lcd screen
As a quick test I would try connecting the monitor to another PC to make sure the problem follows the monitor. If it does then the likely cause is a circuit board or possibly a poor connection inside the monitor. Since working on this would require opening the monitor case and voiding your 1 year warranty I would recommend you contact Samsung support for a warranty replacement as soon as possible. When you do make sure you mention the problem goes with the monitor and any other troubleshooting steps you have taken. Also the replacement they send will itself be something that was returned and fixed.The only warranty you will get will be whatever is left of your original year so definitely get this taken care of as soon as possible.
Jul 11, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Open Questions:
Computers & Internet Logo
363 people viewed this question
David Payne
David Payne
