Question about Jenn-Air Dishwashers
Jenn air quiet series II dishwasher has blinking light on clean and light wash after it only goes away when we push the off didn't used to do this
    New Friend:
  • 42 Answers
Couple of things to check: there's a float that needs to more freely, make sure it does. There's dishwasher cleaning instructions in the operation manual. You may need to take the lower rack out, take off the spray arm to get at a filter, which you should clean and replace. Then you can try to run some white vinegar through a wash cycle. Jean Air has these instruction at their web site.
Posted on Feb 01, 2016
SOURCE: Whirlpool Quiet Partner II
Thank you so much!!! heated dry & hi temp buttons worked!!
Posted on Feb 13, 2008
SOURCE: whirlpool dishwasher # quiet partner II
push" heated dry",then "normal" then" heated dry" then "normal"--it worked like a charm..did the happy dance,washed dishes and saved $130.00!!
Posted on Jan 26, 2009
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
  • 8619 Answers
SOURCE: Clean light is blinking. Services manual says:
Thanks for using FixYa. That means the control sensed that the heater in the D/W did not operate 3 times in a row. So the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. Use a meter to see if it reads open; if so orders a heater assay it will come with a new control replace it too. If heater checks good then press in sequence normal wash, heat dry, normal wash, heat dry, normal wash, heat dry three times within 6 sec and all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that D/W does not heat its own water and incoming water temp should be 120. The D/W will maintain that temp. When starting your D/W first turn on your hot water till it gets hot then start your D/W this ensures your unit fills with hot water and not cold
Please do rate the solution and revert for further assistance.
Posted on Nov 22, 2009
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Posted on Dec 19, 2009
Lock light stays on my whirlpool quiet partner II
If pushing and holding the lock button till the light goes out doesn't work, you likely have a problem on the circuit board.
May 24, 2014 | Dishwashers
Jenn air quiet series ii
had a similar problem i just replaced the drain pump and it worked.
Aug 17, 2013 | Dishwashers
Whirlpool Quiet Partner II dishwasher won't run after power went out. How do I reset it?
I hope it's still in warranty. Usually when power comes back on after a power failure, there is a power surge that takes out electronics.Sad, but true.
Sep 29, 2017 | Dishwashers
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Whirkpool quiet partner 3 dishwasher status stuck on clean. If I press cancel it goes into a 2 minute drain cycle, but there is no water in it. It will no reset or start....just blinks clean.
if you have a heated dry option and normal wash option push those buttons back and forth three times all the lights will come on reseting the board..
push cans. and your done
if this happens again that means you have a bad heater or bad board
Aug 21, 2009 | Whirlpool Dishwashers
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Whirlpl Dshwshr Control Lock light went on/Reg Cycle won't work
Hold the air dry button for 4 seconds. My son just fixed mine with the same problem.
Apr 07, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwashers Logo
493 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
