Question about RCA P61940 61" Rear Projection Television
Stretched screen My picture stretches into an hour glass shape. Color seems to all blend together.
  • dperk Oct 05, 2008
    This does fix the color problem, but not the problem with the screen stretching out of shape.
    Genius:
  • 1,148 Answers
Try the menu under setup, find convergence, it realigns the colors,, you are suposed 2 do that periodicly,, or when u move the tv,, should help you ,, ive got that same tv,,
Posted on Oct 05, 2008
Hello
Posted on Oct 10, 2008
Screen seems stretched. How do I fix it?
60'' Vizio TV screen is stretched in 'normal' screen mode on HD ...
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
TV Problem: The picture on my television is stretched out on the ...
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
How to Fix the Most Annoying Features of Your New HDTV ...
Dec 31, 2015 | Vizio VA Televison & Video
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
The desktop and applications are stretched
right mouse click on the desktop and select properties. Then go to the settings tabe and change the resolution. A picture of the screen shape on that window should give you an indication of whether or not you have chosen a compatible resolution
Jan 06, 2010 | Acer P221W LCD Monitor
Trying to set my background picture and the browse list is lite up but can't scroll and add picture to the customize desktop and only half my screen gets half the picture the rest of the screen is a color....
try playing around with the position options "stretch and the others" and see if that works. make sure you dont have any desktop theme software on your system aswell and if you do, uninstall it.
is it xp or vista?
Apr 26, 2009 | Computers & Internet
Monitor Problem
This is probably the result of using the wrong display driver. It may even be set for an external monitor. If it was used with an enternal monitor, connect it up to the same one (or something similar) and use the display settings to get the computer to use the LCD as the primary.
Jul 09, 2008 | Acer Aspire 5002WLMi Notebook
32 RCA Telvision With Picture Stretch
Mis-shaped pix is often a bad capacitor in scan circuit or a bad
solder connect on a shaping capacitor lead...............T.
Mar 14, 2008 | RCA 32V420T 32" TV
Faulty Lens?
Dear Swetnam
This is a internal circuit problem/defect and cannot be done on our own, so u should take it to SONY service centre. Avoid keeping the camera near hot temperatures zone. Sony is not tolerant to many physical factors.
Feb 07, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Acer LCD AL1716W Monitor shows lines
use 1440 x 990 resolution, the ratio of the monitor is 16:10
Dec 27, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
RCA P61940 61" Rear Projection Television Logo
165 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
