Question about Maytag Dryers
Two things: I would like to disable the annoying buzzer that sounds which sounds when the drying cycle is over. I want to clean out the slot where the lint filter sits, but am afraid to pull very ******* the plastic grate that is in front of it. I have removed three screws (two hex, one phillips) but the grate does not seem ready to be removed. It is an electric dryer, model MDE2600 AYW Thanks.
  • Wolky Oct 05, 2008
    Since I started on the Maytag site I did not specify that it is a Maytag dryer.
  • 706 Answers
Hello Walky,
The vent cavity can be cleaned fairly easily without removing it by adding a section of flex tubing to your vacuum cleaner. Most hardware stores sell clear plastic tubing in various sizes so choose one that will fit inside the lint trap area ( normally ~ 1/2" or so and add that to your vac hose with duct tape or equivalent)... If you slash cut the end of it....you can better vacuum the grated surface inside that filter housing.
The buzzer module can be unhooked from inside the dryer. Try this website for location details
http://www.pcappliancerepair.com/model-display.php Slide 3 Control Panel shows the wherabouts of the buzzer ( item 11 ) which you should be able to disable by removing or cutting the wire ( please do this with the power disconnected . Also , make sure that you cover any exposed wire ends with an electrical tape, wire nut or some insulator to prevent accidental shorts.
Hope this helps you..
Posted on Oct 06, 2008
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
Feb 08, 2016 | Whirlpool Dryers
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Want to disable buzzer
Hello Craig McDaniel - The buzzer signal will sound when the cycle ends and briefly every 5 minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Feb 15, 2013 | Frigidaire FEQ1442ES Electric Dryer
Can you disable the chime at the end of the time cycle on my microwave
Yes , You can disconnect the chime or SOFTEN the chime by just insulating the gong if this is mechanical type or to disconnect the buzzer if this is the electronic control board
Jan 10, 2013 | Microwave Ovens
I would like to shut off buzzer in dryer please do not answer if there is a charge
If you are trying to shut off the buzzer because it sounds constantly, there is a problem with the dryer timer motor, and that is an entirely different problem.
However, if you are like me and find it really annoying and loud - and are trying to disable/remove it this is how to do so:
Tools: #2 Phillips head, 8-10" long
#2 Phillips head, 3" long
Optional but recommended: Vacuum cleaner with flex hose. (Unless your dryer is new or you maintain regularly, it is full of lint that is a potential fire hazard - this is a great opportunity to clean it out)
Optional but recommended: Duct tape, the metallic sealing kind, not the elastic adhesive tape
Steps:
1. REMOVE THE POWER PLUG FROM THE WALL. TURN THE DRYER CONTROL TO TIMED DRY AND TURN THE START KNOB TO ENSURE THE POWER IS OFF (IF THE DRYER STARTS, YOU PULLED THE WRONG PLUG - TRY AGAIN)
Note 1: As you start removing panels, it would be a good idea to clean as you go, otherwise you will have a big dusty mess...
Note 2: As you remove the panels either screw the screws back in to where to took them out of, or screw them into the holes of the panels you are removing, they can get mixed up or forgotten easily...
2. Remove the 2 screws that hold the cover from the underside of the dryer tumbler (above the lid for the washing machine)
3. Remove the 7 screws for the tin sheet that covers the blower/tumbler motor
4. Remove the 2 screws for the front control panel with all the knobs for the washer/dryer
5. The panel can be lowered out slots on each end by applying some pressure inwards, then down. Mine was a little more difficult to remove because of all the lint/**** built up so I used a screw driver for a little prying action. If you try this, pry on a side the that is not exposed in case you cause any dents, scratches, etc... for aesthetic reasons.
6. Once you have the panel down, vacuum this area very well, there are exposed contacts and terminals here that will be a source of ignition if a contactor goes bad and there is a lot of lint build up.
7. On the left side where the dryer controls are, there is is a little black rentangular box with two wires going into it - mine was between the dryer cycle knob and the start knob. It is the only component on the backside of the panel that will not have a corresponding knob on the front of the panel. Remove the screw that is holding it in place, and pull it up at an angle to clear a metal clip that holds it in on the side opposite the screw.
8. Once you have the buzzer free, follow each wire from the buzzer to its termination point on the dryer cycle controller. The buzzer should have black a wire going to the "common terminals" labeled either B or C, the other black wire is for the switch terminal of the dryer cycle controller. There should be "female" connectors on the wires from the buzzer, connected to the "male" terminals of the dryer cycle controller.
9. Remove these female connectors, which will disconnect the buzzer from the dryer. Be sure that you do not accidentally pull off an incorrect wire - and if you do, make sure to reconnect it before removing any other wires to avoid confusion as to what goes where.
At this point, get a flash light and take a look around the inner dryer housing. With your vacuum - if you have a brush attachment, use it - clean out all the built up lint from everything you can reach, especially around electrical connections, wires, the dryer motor windings, etc... Take your time, do it right - you spent the time taking the thing apart, it will not kill you (and actually may save your life) to spend 15 minutes cleaning the inside of your dryer.
If you have some duct tape, tape the blower exhaust connections from the plastic blower housing to the metallic duct and the flexible duct. I also taped the plastic piece that the lint screen inside the dryer door sits in because the foam rubber stripping had come apart. There areas are the main places that lint escapes into the inner parts of your dryer.
10. When you are done cleaning, reassemble the dryer in the reverse order you took it apart in.
11. Once reassembled, plug the unit back into the wall.
12. Turn the dryer control knob to as close to the end of a cycle as you can, turn the start knob to start the dryer. If the dryer starts, then stops at the end of the cycle without a buzzer - you were successful.
Dec 22, 2008 | Frigidaire FEX831CS Top Load Stacked...
How to disable the speed linked seat belt buzzer in my 2007 camry
Your dealer will use their scan tool to interface with your vehicle; that will disable the speed link. I provide this service at no charge.
Dec 18, 2008 | 2007 Toyota Camry
Loud buzzer Model FEX83...
SIMPLE! behind the dash board are screws simply take screws out ane the buzzer shouid be hooked to the timer. there are two ways to do it either cut the wire if you plan never to use the buzzer again or if you want to just unplug it!
Jan 20, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
139 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
