Question about Dell 924 All-in-One InkJet Printer
Error message "Color cartridge missing"
I've installed a new color cartridge and the printer doesn't recognize the cartridge. Cleaning the contacts several times doesn't resolve the problem. The black cartridge is fine (both have been replaced several times in the past). Any ideas?
  • klau0624 Mar 15, 2009
    hp 2710 Photosmart Ink Jet Printer-installed a new color cartridge, still get color cartridge missing error, put the old color cartridge back in, still get same error message. Does any one know how to fix this?
I have put in new black and color the printer does not reconized. It says removed paper and i have
Posted on Mar 17, 2009
  • 661 Answers
Sounds like you got one with a faulty chip, take this back to where you got it from and they should replace without any problems.
Posted on Oct 06, 2008
Printer Does not recognize Color Cartridge Error 3603 for ESP 3250
Are you using "compatible" cartridges? That is usually the problem. Try using Kodak cartridges. If that doesn't work, it's the printhead. You could try cleaning it.
Nov 03, 2012 | Kodak Esp 3250 Allinone Multifunction ( ...
Cyan color cartridge "appear to
http://h10032.www1.hp.com/ctg/Manual/c00485555.pdf
Apr 22, 2011 | HP Photosmart 3210 All-In-One InkJet...
Error message:right (color) carthridge missing
Maybe the cartridge is not seated well in the cartridge carrier or just needs cleaning. Follow the instructions on this link to the Lexmark website on How to Clean the Print Cartridge Nozzles and Contacts Manually. If this doesn't help yet your cartridge is a genuine Lexmark cartridge, I suggest you contact Lexmark Technical Support for further assistance. Genuine Lexmark cartridges shouldn't cause you that much trouble.
Jun 09, 2010 | Lexmark X7350 All-In-One InkJet Printer
Tri colour problembought to refilled cartridges one displays problem other table, is it the refilled cartridges or the printerwrong cartridge 344 not compar
Hello!
When the printer tells you "wrong cartridge", it is because it cannot recognize the cartridge.
Remove the color cartridge and gently wipe the electric contacts on it with a dry cloth. Put the cartridge back in and check for error messages.
If the problem persists, you will need to buy a new color cartridge, because the one you have is damaged- one of the contacts on it has blown, and when you place it in the printer, it won't recognize it, because one of the contacts is missing (that is why some printers give a warning sign "cartridge missing").
Hope that helps!
May 30, 2010 | HP PhotoSmart C4180 All-in-One Color...
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
Check Printer Light Keeps Flashing on C3180 PhotoSmart
No, you do not need 3 cartridges or anything like that. Some cartridges have chips. Yours do not. If the light keeps blinking it means that one of the electrical contacts on the cartridge has blown and now the printer doesn't recognize it. Try printing something, you will get a message "problem with color cartridge" or "color cartridge missing". That means that the printer doesn't recognize it. I suggest you buy a new one. Or, if you have an old one, try putting it in and see if the light still blinks.
Jun 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
Printer does not recognize new color cartridge
Make sure you have taken the orange tape off the print cartridge.The printer will not recognize the cartridge with the tape on
Mar 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Cannot print true color.
How do I resolve the error message "Calibration Page Not Found"? Error code: 3610 Question : How do I resolve the error message "Calibration Page Not Found"?
Answer : To resolve this error condition, correctly position a calibration page on the scanner. See the User's Guide for more information. How do I resolve the error message "Cover open"? error code : 3501 Question : How do I resolve the error message "Cover open"? Answer : To resolve this error condition, close the access door. The printer will not operate while the door is open. How do I resolve the error message "Color ink cartridge missing or not installed correctly"? Error Codes : 3511 Question :
Answer :
To resolve this error condition, reinstall the ink cartridge:
  1. Remove the color ink cartridge:
    1. Open the printer access door by lifting from the front center of the unit.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
  2. Check the two electrical contacts on the ink cartridge for small marks, which should appear if the cartridge was installed correctly.
    If the electrical contacts do not have small marks:
    1. Reinstall the ink cartridge, making sure you press down on it until it clicks into position.
    2. Remove the color ink cartridge, then check the two electrical contacts on the ink cartridge again for small marks. Repeat if necessary.
    3. Reinstall the ink cartridge.
  3. Close the printer access door.
NOTE: See the User's Guide for more information about removing and installing the ink cartridge.
If the error persists:
  1. In the KODAK All-in-One Home Center, select the Help (?) icon.
  2. Select Maintenance.
  3. Select Firmware Upgrade, then follow the prompts to download the latest version of firmware, free of charge.
From Kodak support:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=9104/7269&pq-locale=en_US
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
178 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
