Question about GE Nautilus 24" Built-in Dishwasher
Ge nautilus leak left side
My dishwasher is leaking from the front left side. I pulled it out and the leak is coming from the side where there is a black hose??? I tried to push it back, but it didnt seem to work. Any ideas ??
    Sergeant:
  • 276 Answers
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Nov 20, 2008
Leaking aroumd the door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
,,n
Jul 28, 2010 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus is leaking from the bottom of the door
Leaking Dishwasher
heatman101
kkm
Jul 25, 2010 | GE Nautilus 24" Built-in Dishwasher
GE DISHWASHER LEAKS AT LEFT CORNER
Have the same dishwasher and happens sometimes to mine when the door doesn't close properly because it is hitting the cabinet front. Try pulling up and forward from the bottom of the door when it is closed. if the bottom comes forward this could make the difference and stop the leak.
Jan 25, 2009 | GE Nautilus 24" Built-in Dishwasher
Leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Nov 09, 2008 | GE Nautilus 24" Built-in Dishwasher
My dishwasher is leaking from the conors and sides
I replaced these black corner gaskets and it still leaked.....GOOD LUCK!
Nov 03, 2008 | GE Nautilus 24" Built-in Dishwasher
Motor
The only reasons to replace a pump motor are very loud motor or leaking water from the seal of the pump / motor assembly. The motor comes as the pump / motor assembly, and is not real cheap and not particularly easy to replace, so you may want to consider cost of replacing the entire unit. Appliance repair locations can order for you, or you can order directly from GE over the phone. (GE answer center 800-626-2000) Make sure you have complete model number, located on the sticker on the left side of the tub just inside the door.
Sep 01, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
794 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
