Question about Panasonic KX-TG1033S Cordless Phone
KX-TCA115EX How to turn off ringer on base unit?
  • zvelickov Oct 06, 2008
    1. Press Menu button
    2. Press multibutton "down" repeatedly to display "settings BS", then press multibutton "right" {>}
    3. Press {2} two times
    4. Select the desired setting by pressing {1} for low, {2} for medium, {3} for high or {0} for off.
    5. Press multibutton {>}, then press on/off button
5 Suggested Answers
SOURCE: ringer
Thats it....
Have fun
Posted on Jun 24, 2008
  • 6 Answers
SOURCE: Ringer settings on 8825 base unit
You can adjust the volume and pitch of the ringing by pushing Menu, scroll forward to Desk Station Settings, push Select, scroll to Ringer Volume and you can adjust the ringer volume, and in that same area adjust the pitch. So you might want to make line 2 ring lower, and with a different pitch so it is not distracting, but still notifies you of an incoming call that is not line 1. The same goes for the handset.
Posted on Jun 07, 2008
SOURCE: How do i turn the
It's in p.25 of the manual: press Line Select until the line you want is displayed (can't do both at once). Press the down arrow (on the volume button) until two beeps sound. That's it!
Posted on Jan 16, 2011
  • 1196 Answers
SOURCE: The visual ringer switch on
I will suggest you reset your phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem. If that did not fix the problem, let me know.
Posted on Mar 10, 2011
How do you turn off the base ringer?
You don't have to unplug anything. Just set the ringer volume (feature code 11) to 0.
Full details are on page 27 of the manual.
Mar 16, 2012 | Panasonic KX-TG6022B Phone
HOW DO I TURN THE RINGER ON. HAND SET READ RINGER OFF
Temporary ringer off While the handset is ringing for an outside call, you can turn the ringer off temporarily by pressing {OFF}.Adjusting the base unit ringer volume Press {^} or {V} repeatedly to select the desired volume.To turn the ringer off, press and hold {v} until the unit beeps 2 times
Sep 22, 2011 | Panasonic KX-TG5632 Phone
The ringer on the phone is off. So, when the phone is off the base unit, I cannot hear it ring. How do I turn the ringer on? KX-TG2730
Hi! Most phones have a double function for the "#" key. Press and hold this button "#" and the silent mode will turn off/on.
I hope this will help you! Have a nice day!
*please don't forget to rate my services :)
Sep 03, 2011 | Panasonic KX TG2730 Cordless Phone...
DOES Panasonic - KX-TGA110EX - support Onscreen caller id
Have two Panasonic KX-TGA110EX and two KY-TCA115EX phones and their appropriate base stations. Can they be used as a single network?
Yes, I hope but suspect no!
Peter
Mar 08, 2011 | Panasonic KX-TG1100 Cordless Phone
KX TGA244B How do I get the ringer back on
Handset ringer volume
4 levels (high/medium/low/off) are
available. The default setting is HIGH.
1 Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Ringer volume” by pressing
4 Press {V} or {^} repeatedly to select
the desired volume.
LTo turn the ringer off, press {V}
repeatedly until “Off ?” is displayed.
5 Press {Save}.
Note:
LWhen the ringer volume is set to off, the
handset will display “Ringer off”, and
will not ring for outside calls. The
handset will ring at the low level when
paged by the base unit.
Jan 05, 2010 | Lands Phones
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
Ringer
Hold the Low volume key on the base unit for sometime. A beep will sound that means the ringer of the base unit is off.
Feb 18, 2008 | Panasonic KX-TG5632 Phone
Ringer
Thats it....
Have fun
Nov 19, 2007 | Panasonic KX-A143 Phone
Panasonic KX-TG1033S Cordless Phone Logo
2,081 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
