Question about HP PSC 1210 All-In-One InkJet Printer
It won't print, It says Door open, what does that mean.
The printer will not print, it say door open.
Well it means the top of it is not closed so try closing the cover then printing hope i helped
Posted on Oct 18, 2008
otacon
  • 1944 Answers
SOURCE: Printer Door
I have that exact problem at work. There is a bump on the right side of the lid...and when you close the lid it presses on a lever. Check and see that the bump actually pushes that lever downwards. That's how the printer determines that it's closed.
Posted on Feb 03, 2008
MUKHTAR
  • 2022 Answers
SOURCE: Not printing
pls reomve all the print job from print spooler like just double click on the printer icon it will shows the list of pending job pls clear all the documents and restsrt the sytem and then give the print command it will work.
Posted on Nov 19, 2007
gadgetboy21
  • 15 Answers
SOURCE: printer says door open
aah simple solution to that modiboni. you need to check if the printer door is still open but youv already tried that im sureoption 2 im not to sure on your printer but when you open the door chek to see o protruding plastic that will activate a switch to say the door is closed if you see that the plastic is broken use a small item to push down the sensor and it hopefully should read that the printer door is closed.
Posted on May 13, 2008
SOURCE: hp laserjet 2600n printer showing message door open
there door censer problem. i fix new censer
Posted on Jul 10, 2008
  • 113 Answers
SOURCE: Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Posted on Feb 28, 2009
Code:08-100,what this code means?
Error means the leading edge of the sheet of paper did not arrive at the preregistration sensor in time, causing a jam.
To fix - Open the inverter door and clear area 14. Open the printer right front door and clear area 2. Retry printing.
Nov 06, 2014 | Xerox WC 4150 NETWORK ACCOUNTING...
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
Mar 12, 2014 | HP PhotoSmart C4345 AllInOne InkJet...
Won't scan, error message -scanner door is open
Simple solution. I just had the same problem. Make sure the top cover on the left side is snapped in. It wasn't obvious that it was open. They should probably give a better code because it is not the scanner door that is open.
Apr 16, 2013 | Samsung New-scx-3405fw Wireless...
Cartridge door open message won't go away
see door switch your door switch have problem
May 27, 2012 | HP Office Equipment & Supplies
HP psc 1210 won't print. screen says i have a door open
you need to close cartridge access door Close it
Hope this helps,
Lucas
Jul 07, 2011 | HP Office Equipment & Supplies
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
What does ! in a circle mean on an HP 2035n printer
The printer cartridge door is open. Attention
The print-cartridge door is open. Close the print-cartridge door Attention
Jan 28, 2011 | HP P2035N LaserJet Monochrome Printer
Printer won't print - says door is closed, even when it's open
your door open sensor is not working proper.pls close this cover tightly..
Aug 16, 2009 | Office Equipment & Supplies
HP PSC 1210 All-In-One InkJet Printer Logo
3,026 people viewed this question
Ben Johnson
