Question about Garden
My ryobi bc30 trimmer runs but when I give it gas, it dies
When I start the trimmer, in the start position, it runs like it supposed to. When I go to use it, give it some gas, it dies. The last time I used it, about 1 month ago, it worked fine. I got to experimenting with it and found in the start p;osition, give it some gas it runs, put it in the run position, and give it some gas, it dies.
my email is wyomingterry@yahoo.com
  • 4 more comments
  • jollyroger4f Oct 07, 2008
    Same problem.
  • brezdog13 Oct 10, 2008
    changed gas and plug still will not run right
  • cwhams Oct 18, 2008
    I have done a little more analysis. In my case, it appears to die with the load on the end (trimmer, blower, or edger). Without the load it runs at full throttle just fine. New spark plug and gas bought today!
  • heisiseissen May 04, 2009
    I also have a BC30 (p.o.s.) trimmer. It quit running and I discovered the screws holding the cylinder to the crankcase were either loose or broken. I replaced the broken one and assembled it but it needs mixture adjustment. It has tamper proof high & low speed jets. The head of the jets are about 5mm dia with a notch on one side. They are surrounded by the cast carb housing so are impossible to turn without the tool. I guess you get what you pay for.
  • Anonymous May 12, 2009
    i feel like ryobi has a bad carb design. having same problem with no solution. i have even taken carb apart and cleaned ran good one time and back to same thing
  • ssk1000 Mar 25, 2012
    Same problem. Where are the dang mixture screws. People are handy enough to rebuild the whole carb, but can't figure out how to take a picture? : )
    Read that some later BC30's don't have adjustable jets on he carb (seems strange).
I have the Ryobi BC30 trimmer, also. For a year now, it would only work on half choke. Putting it in run position would cause it to quit. Also, it would no longer idle...it would quit if I idled it for too many seconds. I had not used it in a long while. It would then not run in half choke position and would die in idle. I figured out that if I kept moving the choke lever between full choke and half choke, I could keep it running. I checked the internet for what would cause this. I was using NEW gas and oil. I had replaced the fuel tank because of a hole in it that nothing would seal. This means I had a new tank, fuel filter, and fuel hoses. So, this was not the problem. Since it runs fast between choke and half choke, the basics of the system were fine. I took the carb apart and cleaned whatever I could. Took out the little fuel filter screen and cleaned it. No difference. I took off the exhaust module and looked at it and the screen that is the flame arrestor (mentioned on the internet). It was fine. Of course, folks mention using carb cleaner spray into the air filter port (oh yeah, I had replaced the air filter with a new one earlier). Sprayed repeatedly and no difference.
So, here is WHAT DID WORK! Took the carb off (pretty easy (two nuts to remove, take off the two fuel lines, and remove the little wire that controls the throttle)). Now, take the carb apart carefully screw at a time...geez, there are only two sides! Be careful with the gaskets. One has a thick gasket and a thin one sandwiched together. Pry these apart and clean them (with the carb cleaner spray you already bought). Put them back together and lay aside. Take the other side of the carb apart (another couple of screws?). Need I say to lay everything you take apart on the ground in the order you put them back together? Now you have several big pieces of carb and several smaller plates from each side. Now take your carb cleaner can with the small red straw. Place the straw in EVERY hole you can find on the big pieces and small pieces. Either where goggles or some kind of eye protection. BLAST out all these holes until either fluid comes out ANOTHER hole or obviously this hole goes nowhere. If these holes spray out fine elsewhere, then spray it out backwards through those holes! Be sure to take the fuel filter screen out of its hole (you will just have to find this screen in a fairly large hole in one of the BIG carb parts). Clean the screen by spraying the carb cleaner into it until you are sure it is clean. Place the red carb cleaner straw into the screen filter hole right on the TINY hole at the bottom. Look at the reverse side of the carb. There is a mechanism on a rocker arm that moves up and down with a little push on a flat metal piece. This is the reverse side of where the big hole is that had the screen in it. Blast this out with the carb cleaner while pressing on and off of the flat metal bar on the reverse side. You will see that the flat metal piece is attached to a pole that disappears towards the large hole on the other side (the one that had the screen in it). While blasting from both sides, you will only get a little spray come through. Just keep blasting to clear this component. This is really the only tricky part to clean. ALL the other holes generally will either clear out pretty quickly or there is nothing in the hole. The idea is to BLAST ANY hole you can find in ANY of the parts. Like I said, be careful because while you are blasting TINY holes, you will get a good bit of blast back from the hole you are in. This will cause spray to hit your hands, face, eyes, etc. BE CAREFUL. Don't be a wimp, just protect your self. The carb cleaner is under pressure. It will come out COLD. If you have cuts on your hands, it might even sting. It will also DRY out your fingers if you get enough of this stuff on you. Either wimp out or keep going. If your fingers are getting too cold because of the over spray or back spray, or the carb is freezing, then back off for a bit. This is a disclaimer! Right now my fingers are VERY clean and VERY dried out (but my BC30 works fine!).
Ok, you have sprayed all the holes and figured out that any thru-holes is now clear. Put all the parts and gaskets back together. Reattach the fuel lines to the proper spouts, reattach the throttle control s-curve wire properly. Reattach the carb to the unit with the ONLY TWO nuts. You are now all together again with a really clean carb.
Fill the fuel tank with FRESH GAS from the gas station with the proper oil mixture (come on....just buy the small oil bottles that you use the whole bottle per a gallon of gas).
Ok, you are now starting out with what ought to be a VERY clean carb. THAT problem should be over! What may not be over is that the idle and the high speed may not be working. Remember that my unit would not idle...it would cut off at idle. This procedure cleaned that right up!!!!!!!!!!! The other problem was it would ONLY run at half choke and then less than half choke. Run position would stall and stop.
So, now you need to start the blasted machine. I tried using the proscribed method using FULL choke for a bit, and then half choke. I had waited awhile letting the carb cleaner to evaporate. Don't know. It did not want to even start for awhile. SO, I tried to get it to start in the manner that was working BEFORE I started all this junk. I put the lever in a position between full choke and half choke. This was a very hard position to maintain in order to keep the lever from moving. I had to press the fuel bulb a few times every now and again. I was pressing the FULL POWER button. All of a sudden, it started. And what to my surprise, when I took my hand off the throttle, IT STAYED running! This was PROGRESS!
Now, I put the lever in half choke position and pressed the throttle button. It cranked right up! I was at least back to where I was a year ago. When placing the lever in run position, it tried to stall out as it did a year ago. That was ok, I was making progress. I fiddled around a bit keeping it running and ascertaining that in half choke mode AT IDLE, the unit STAYED ON also at full throttle. I am stoked because I feel the carb is fully cleaned and none of the holes are clogged. So, NOW I feel the only problem is the screw that controls the jet of fuel when the unit is in RUN mode is the problem.
MY UNIT has the TWO screws on the side of the carb. The one closest to the engine controls the IDLE speed of the unit. Since, my machine now idles without cutting off, this screw must be adjusted fine. This also means that one of the holes that deals with the idle was clogged...and my efforts of blowing out ALL the carb holes has fixed this problem. The screw that is FARTHER away from the engine controls the HIGHER speed which includes the RUN position.
So, I took a flat head screw driver to adjust this screw (the OUTSIDE screw). I started the machine in the HALF-choke position that was WORKING. I then turned the outside screw COUNTER-CLOCKWISE a quarter turn. I then moved the lever to the RUN position. It STILL RAN! WOW! But then, as I revved the engine up and down, it slowed down a bit and made me think it might quit. Put it back in half-choke position and it ran fine and revved back up. I then adjusted the outside screw some more in the counter-clockwise position and went back to the RUN position with the lever. I am making progress. I reached a point where I could leave the lever in the RUN position and kept adjusting the OUTSIDE screw counter-clockwise until the unit would go from idle to full speed in the RUN position without stalling or sounding funny. The end result was that the full power was operational and when I let the throttle go, the unit revved down but kept running fine.
My RYOBI BC30 now runs just as well as it did when I first bought it. I did NOT have to buy a new carb OR a carb kit! I was careful with the existing gaskets (one gasket was broken on the OUTSIDE of the screw it went through but had no effect (the outside was far enough away from the inner important area)).
So, here is the deal. If your Ryobi BC30 only runs when you have it set on half choke or less instead of the RUN position (BUT IT RUNS), then your CARB probably has some plugged up holes in it. If when in idle, it quits, then some hole(s) are clogged. The fix is to BLOW out these holes! I used carb cleaner over and over again until I felt the holes HAD to be clean (spray easily came out somewhere else). Some people say to use canned air to clear out the holes. I had the carb cleaner but not the air. So, I did it with the carb cleaner pressure. This worked.
I must say that EARLIER in my trouble shooting actions, I found bits and pieces of what I figured were bits of gasket material which I removed early on. When you take the two nuts off those LONG two screws that hold the carb to the unit, it is hard to remove the plastic air filter unit. Because of this, it is possible to strip some plastic off the air filter unit that might get into the system. So, be careful here. I had to force the plastic unit off...it simply was very tight...so be aware of this. It was so tight, that I looked many times to see if there was something else holding on to it.
Last deal. You can clean the carb. You can adjust the screws if your unit has them. I have heard that later modules do not have the idle adjust and high speed adjust screws. If yours does not, then follow my directions to clean the carb. I have no idea what to do about the screw adjustments if your module does not have the screws. Troup Nightingale
Posted on Jul 31, 2010
  • Marty Gunderman
    Marty Gunderman May 09, 2014
    I was only searching for the idle and run callouts but I've never seen such excellent instructions for anyone to understand. Great work!
  • Fonky Rob
    Fonky Rob Feb 12, 2017
    My BC30 had the same problem, usually I would replace the fuel filter, use fresh gas, gap the plug and it would go.
    This post solved my problem, mine is the model with the elusive triangle mixture screw that I left alone.
    You saved me $300 that I would have spent on a Toro at Home Depot!
    It runs like a bat out of hell again.
    Thanks Troup!!
My Ryobi BC30 would idle great but when I would accelerate it to high speed it would die. Might die after 30 seconds or minute and a half or whatever. Finally ended up taking the handle apart and discovered that the kill switch wires were not put in their proper channel at the factory and had finally worn through and would short out against the metal shaft when there was enough vibration at high speed. Taped them and put them in their channel and reassembled. Problem solved!
Posted on May 31, 2009
  • Gary Blackstock Feb 05, 2016
    Thank for the info. I check the wires and they were fine.
Fuel delivery is very important to this trimmer. I would check the fuel lines going into the fuel tank. The gas seems to soften them over time and any cracks or breaks will cause running problems. Also the venting or non-venting of the fuel tank seems to have extreme effects of performance too. Im ready to throw this thing in the trash. Spending way to much time trying to keep it running if you know what I mean... GoodLuck.
Posted on Jul 19, 2009
    Thank for the info. I put new fuel line on the trimmer.
    Scholar:
  • 62 Answers
I don't mean to over simplify this, but are you using fresh gas? And when I say fresh, I mean fresh from the pump, not the gas can. Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem greater than 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 09, 2008
    New Friend:
I worked on a ryobi trimmer model 30002A 30cc engine and the problem it had was the bolts holding the top part of the motor that you put the spark plug into and mount the carburetor on was loose from the bottom half of the motor and had lost just enough compression to to be hard to start and it would also only run at full throttle and would not idle. I tightened up the three torx bolts and the unit fired right up. I believe I read somewhere that these units are notorious for those bolts loosening from the vibration of normal operation. I would keep check on this after each operation to see if you can wiggle the carburetor or the spark plug then the block has loosened on you.
Hope this may help
Posted on Sep 26, 2013
    Thank for the info. I check the screw they were tight
    Problem Solver:
  • 6 Answers
Hi
I have the exact same trimmer as you. I would reccomend taking apart the carburetor and cleaning it with carburetor and choke cleaner. If that doesn't work, then go to some kind of yard sale or flea market, and find a weed wacker, chainsaw, or some other kind of small engine that is or looks to be in a good working condition, and buy it for a reasonable price. This price range would be anywhere from 2-10 dollars (depending on its condition and the buyers willing-ness to neogotiate with you). HINT: Most of the time you can get the product from them for about 50% less than what they originally asked for it. They usually want ot get rid of the stuff so they dont have to load it all back in their car at the end of the day. But anyway, once you get it back home, clean and switch the carburetors between your Ryobi and your newly bought machine. once thats done, giver er' a go! Hope this works out for you, and good luck!
Posted on Jul 14, 2009
What is gap clearance for sparkplug on ryobi bc30
to be honest dont bother with it it will be cheaper to buy new but i would stear clear of ryobi
Jun 19, 2010 | Ryobi Garden
Ryobi EX26 dies when hot, won't start, then when cool starts
This sounnds too good to be true, but believe it!
The next time you run the trimmer and it starts to die, loosen the gas cap. It should start to run again. This means that the gas cap is clogged. Either clear the gas cap or buy a new one. This should solve the problem.
If you need further assistance, just let me know.
Jim
Jun 30, 2009 | Ryobi 15" Electric Factory Reconditioned...
My new Ryobi boggs down/ stalls as soon as I pull on the trigger.
You should have 2 small adjuster screws next to each other on top of the carb.Try adjusting each of them a little with a thin screwdriver as the engine is running.Put strimmer on the ground first and adjust screws while you are revving engine until it runs correctly.Trial and error and very small adjustments can make quite a difference.Hope this helps.
Jun 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas trimmer stalls when lowering the revoutions
do you have the right kmix fuel to addat start on choke let run tell it dies then pump the ball on half choke and chage the plug
May 15, 2009 | Ryobi 15" Electric Factory Reconditioned...
I have a Ryobi trimmer and when I start it will not stay on
Here was my solution:
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel too, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Now to the easy part: The "L" screw adjusts the idle fuel mixture and the "H" screw adjusts the full throttle fuel mixture. turning the screws clockwise make the machine run leaner (less fuel) and counter clockwise makes it run richer (more fuel).
-I started out by turning each screw 1/2 turn counter clockwise and started it up, then as it was idling, i started adjusting the "L" screw as i was moving the choke position to run, after a few full turns counter clockwise of the "L" screw, it was idling perfectly in the run position, then i did the same thing the the "H" screw while holding down the throttle and i got it to run perfectly in the run position. Now it is running way better than it ever has. I hope this helps everyone.
Good Luck!
Mar 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
12,186 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
