Bosch wff2000. goes through program but drum not turning. creating a sparking sound when spin intermitently works
  • moyarooney Oct 11, 2008
    Thanks. Carbon brushes was the problem. Got local guy in to fix. Cost £45. Now up and running. Didn't get the commutator checked though. Does that usually fail at the same time as the brushes. If so is it easy to fix?
  • 14 Answers
It sounds very much like the carbon brushes in the drive moter. the best way is to remove the motor and then you can also check the commutator for wear as well. model no and serial no needed to get spares, sometimes moter type.
Posted on Oct 06, 2008
I've a 97 bosch wff2000, washes, drains but will NOT spin either after main wash, rinse nor does it do the final spin. Had it from new, so definately can't complain. I've just replaced brushes...
Try disconnecting the small bore hose from the pressure chamber it could be the switch has stuck in the on position in which case the pressure chamber is blocked (the chamber is at the other end of the small bore hose )
Mar 28, 2017 | Bosch Washing Machines
My WFF2000 machine will not drain or spin. Can you help?
If the washer does not drain, then it will not spin anyway.
Sounds like a blocked filter.
It should be located at the bottom front right of washer./Unscrew anti-cloickwise to remove and clean, if this does not cure it, then the pump itself could be faulty.
Jan 12, 2011 | Bosch Axxis WFL 2060 Front Load Washer
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
My Bosch washing stared making fizzing sparking noises when spinning the other day although ran OK, then it started to blow the trip before being unplugged. On trying again, it fills and drains OK but the...
Sounds like the motor coils are gone ,The armature would have been arcing hence the sounds you heard this may be cured by replacing thermal cut out ..This is Buried within the coils.....Check wiring to the brushes are ok also
Apr 13, 2010 | Bosch Classixx WFC 2465 Front Load Washer
No user's manual for Bosch WFF2000
Donna,
Give this a try! This might be just what you're looking for, but unfortunately, there isn't a model number provided for the download.
http://laundry.manualsonline.com/manuals/mfg/bosch/bosch_washer.html
If that doesn't give you what you're looking for, go to the link below and enter in your information and Bosch will contact you directly and should be able to provide a link for a downloadable (free) manual for your washer.
http://www.bosch-home.com/us/bosch/customer-care/contact-us.html
Another possible source, although I've not used them before is the following link. You'll need to provide your information for them to send you an email, but not sure if the provide free manuals, or charge a small fee for their service. There is no cost to at least enter in the search parameters to find out.
http://www.2instructions.com/search.php?cmarque=BOSCH&modele=WFF2000
Hope you find this Very Helpful and best regards!
Oct 16, 2009 | Bosch Washing Machines
Drum is sparking when spinning the clothes
Sounds to me as though the main drum bearings have gone and the drum is catching the internal parts.
I f the drum is turned by hand and it feels rough or is noisy, then it is the main bearings.
Sep 24, 2008 | Creda W120VW Front Load Washer
Bosch wff 2000 washing machine - won't spin/drain
How did you solve this problem. I have the same problem. Kiran
Mar 09, 2008 | Washing Machines
Wont spin, and arcs.
2 bruhes in motor
replace motor brushes
use correct brushes from bosch
Oct 09, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
