Question about SanDisk Sansa e130 MP3 Player
My player is on mute how do I "unmute"? - SanDisk Sansa e130 MP3 Player
  • Anonymous Nov 25, 2008
    my sandisk mp3 4-gb is freeze ican't charge or put music
How do I unmute a Motorola flip phone?
when you are in a call there should be a mute button that says mute or unmute or microphone. make sure if it is a word it says mute or if it is microphone that there is not a line through it.
Motorola Support
Oct 06, 2014 | Motorola Cell Phones
Turn off mute
upgrade your flash player software it may help. because youtube programs play via flash player.
Feb 11, 2014 | Compaq Computers & Internet
My H710 is on mute - how do I take the mute off??
To mute or unmute a call on your Motorola H710 Tap both the volume buttons until you hear a mute tone.This will mute or unmute the headset during the call.
Hope you're satisfied with my solution.Thanks for choosing Fixya.
Jul 10, 2011 | Motorola Mobility H710 Bluetooth Headset
I can hear a caller but they cannot hear me...muted I think. Hoow do you unmute?
problem might be in u phone mobile u can not mute u r voice ..only in player u can see the mute option, so change u r mic..then it ii work..
Feb 19, 2010 | Motorola Cell Phones
How do you unmute a rip speed dv710 cd player, it seems to be stuck on mute.. im pressin the mute button but nothins hapenin??
my unit only muted when the engine was running it was on telephone mute or something (redphone at corner with cross thru it)to get the unit unmuted while the car (corsa B) was running i had to cut the brown wire labeled mute at the back i jst covered the bare wires with some tape and it worked fine
Jul 23, 2009 | Car Audio & Video
Phone is muted...No one can hear me when I am calling, or answering a call. I can hear them fine. Phone shows "muted"?? How do you "un" mute?
Receiving Calls
1. To answer a call, touch or open the slide.
 If the slide is closed, simply slide it up.
 If the slide is closed, press the Voice
Commands key twice, then touch .
 If the slide is open and the touch buttons are
lit, touch .
NOTE If you touch Left Soft Key [Quiet] while the
phone is ringing, the ringing or vibration is muted
for that call.
NOTE If you touch Right Soft Key [Ignore] while the
phone is ringing, the call will end.
Mute Function
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^
try download the manual if you loose it
Jul 03, 2009 | LG CHOCOLATE VX8500 Cellular Phone
all you should have to do is turn the volume up
Feb 04, 2009 | Rockford Fosgate RFX-9200 CD Player
Can't get it off of mute
O.K. this was a tough one.  I started here. Without asking for help in the sansa forum I reviewed the entire user manual.  This manual (as you may already know) does not contain the words "mute" or "unmute". So I will refer you to the forum sansa has set up for users.
retrevo is a great source for manuals, reviews and support for all electronics.  I would go to the support group sansa has and ask there.  If no unmute is found, this solution will surely unmute your player.  However if you do resort to this your player will be reset to factory settings.  This will not affect memory, but all your system settings will be reset.   That means any customized wallpaper settings, art displayed in lists, backlight, power saver, language, date and time, brightness and volume settings will be restored to their original status!  Memory content will not be affected!  Only formatting the memory drive will delete memory content. So...
This will restore the player to its original factory settings.
1. Press Home button to return to the Main Menu.
2. Select Settings.
3. Scroll down to System Settings and select it.
4. Scroll down to Reset Factory Settings and select it.
5. Use thumbwheel to highlight Yes then press the Select button.
Jan 08, 2009 | SanDisk Sansa Fuze MP3 Player
do you have anything hooked up to the mute cable? if not make sure you have black tape around the open end
Feb 27, 2007 | Pioneer DEH-P6500 CD Player
Open Questions:
SanDisk Sansa e130 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
